I Only Want to Connect/Use Keyless Entry/Exit
geepherder
Platinum - Posts: 3,668
Posted: March 07, 2019 at 3:56 AM / IP Logged Link to Post Post Reply Quote geepherder
Do you have the orange and orange/black to ground, and yellow and yellow/black to constant 12 volts?
Is the red connected to constant 12 volts and the black to ground?
The brown wire is your positive parking light output.
horacecain
Member - Posts: 6
Posted: March 08, 2019 at 7:55 AM / IP Logged Link to Post Post Reply Quote horacecain
Geep,
I am bench testing the unit in doors.
I am using a 12v DC power supply.
When I connect the wiring, I hear the hear unit click. The indicator light supplied stays solid blue.
Nothing happens when I press the remote buttons of the fob. The actuator is connected from the white, white/black to the blue and green wore on actuator.
Perhaps I need to be explained this wiring like I am a baby!
Thank you for your time.
mr
geepherder
Posted: March 08, 2019 at 2:24 PM / IP Logged Link to Post Post Reply Quote geepherder
I honestly can't tell if you are being serious or joking. I meant no offense.
Have you checked for instructions on how to program a remote? It's possible it was lost from programming. If not, contact customer support or the seller.
Platinum - Posts: 13,725
Posted: March 08, 2019 at 4:41 PM / IP Logged Link to Post Post Reply Quote i am an idiot
In figure 2, what did you connect to the yellow and the yellow/black wires?
What did you connect to the Orange and Orange/Black wires?
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
