555l
Digger67
Member - Posts: 23
Posted: November 12, 2003 at 2:50 PM / IP Logged
Hello All, I have searched but can not find a answer to one quick question. I am installing a autostart aw6000ts and using the 555L modual to bypass my Passlock 2 system. Now the question I have is off this 555L it has a blue/black for (-) status input. Is this a ground when truck running or when truck is not running? and the pink wire(+) ignition input this is constant power when truck running. Thanks for any and all help with this in advance.
Digger
vaderfop
Copper - Posts: 95
Posted: November 12, 2003 at 2:55 PM / IP Logged
the pink wire needs to be hooked up to your ignition wire in your steering collum.
the blue/black needs to be hooked up to the (-) status wire from your rs brain.
Remember check all your wires with a DMM!
Digger67
Member - Posts: 23
Posted: November 12, 2003 at 3:00 PM / IP Logged
Ok got the pink part but sorry a newbie here is the (-) status wire ground when running from the alarm brain?
Thanks again.
Digger
tjdurham
Copper - Posts: 180
Posted: November 12, 2003 at 10:52 PM / IP Logged
YES YOUR RIGHT - STATUS IS GROUND WHEN RUNNING I THINK ITS WHITE ON AUTOSTARTS
tj
Digger67
Member - Posts: 23
Posted: November 13, 2003 at 3:35 PM / IP Logged
Thank you
Digger
Wednesday, July 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
