remote start on manual trans.
Focusedonsound
Copper - Posts: 95
Posted: December 22, 2003 at 2:16 PM / IP Logged
Crudeau,
I believe that they are refering to retro fitting a regular remote start made for a automatic trans mission to work in a manual trans car.
I don't know that its illegal however like everyone above has said it is risky.
Atleaset with the models that are made for a manual trans they have some preventive steps... if you do some searching on this board about manual transmissions .. you will find out...
crudeau
Copper - Posts: 150
Posted: December 22, 2003 at 2:58 PM / IP Logged
I have 2 viper 550ESP and a Viper 790CX (or vx one of them).    All I had to do was wire a relay up to the clutch swich and the negative output of the remote start.    I tested it in gear and after 3 attempts at starting it moves the car about 1.5' with the parking brake on.  I never leave the car in gear and don't park on hills so I haven't had an issue yet.  Some day someone will invent a Netural saftey switch for manuals.  Till then, I am rebel with a remote start! remote start on manual trans. - Page 2 - Last Post -- posted image.
joegreene58
Posted: December 22, 2003 at 8:31 PM / IP Logged
I installed a DirectStart423 designed for manual. Its design is to put the vehicle in neutral,press the parking brake. activate the remote while the vehicle is running,remove the key,exit the vehicle and then kill the vehicle with the remote button.if the door is reopened it will not start.
crudeau
Copper - Posts: 150
Posted: December 23, 2003 at 9:20 AM / IP Logged
Sounds like some steps I would forget.  Someone should invent some kind of unversal ring with some switches in it.  Fits around the shifter and if not in neutral it grounds out.  This could be used as a neutral saftey switch.
Teken
Gold - Posts: 1,492
Posted: December 23, 2003 at 10:43 AM / IP Logged
crudeau wrote:
Some day someone will invent a Netural saftey switch for manuals.remote start on manual trans. - Page 2 - Last Post -- posted image.
http://peripheralelectronics.com/2002/security_bypasses.asp
You ask and you shall recieve. It is called a NSS it is at the very bottom of the page.
Merry X-Mas
Regards
EVIL Teken . . .
