w7 and amp question
Kid777
Member - Posts: 18
Posted: February 26, 2004 at 10:31 PM / IP Logged
Hey my friend is interested in getting a jl w7. The question is how can you wire a single w7 ohm wise? i know its a 3ohm sub. Can you get this to a 2ohm load?
thx
E
turbod16y8
Member - Posts: 10
Posted: February 27, 2004 at 1:20 AM / IP Logged
nope. you can only wire it to 6 ohm or 1.5ohm.
Two 13JLw6v2 PPI 2350 Alpine 7995 MB quarts
Ravendarat
Platinum - Posts: 2,806
Posted: February 27, 2004 at 1:35 AM / IP Logged
If you need two ohms, tell your buddy to buy the MTX 9500. Sounds better and hits higher spl in the same conditions.
94bonny
Copper - Posts: 108
Posted: February 27, 2004 at 10:11 AM / IP Logged
if your goin with a jl w7 get a jl amp to match it unless you already have an amp that works best at 2 ohms..
customsuburb
Gold - Posts: 1,813
Posted: February 27, 2004 at 10:34 AM / IP Logged
Your best option is to get a good amp like JL's 500/1 or 1000/1. Or you can buy a good crossfire amp or something like that. then wire it for 1.5 ohms. You can only wire this sub for 1.5 ohms or 6 ohms like turbod16y8 said.
Kid777
Member - Posts: 18
Posted: February 27, 2004 at 1:10 PM / IP Logged
okmthx i'll pass the info along
crudeau
Copper - Posts: 150
Posted: April 14, 2004 at 9:52 AM / IP Logged
only the 13.5 W7 has dual voice coil's?  I have a 12w7 and it's 3 ohms, no options about it.
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
