12volts | WHITE/ black to orange (10A) | + | ignition harness |
Starter | see notes | | |
Notes: There is a white (to WHITE/ blue) wire and a WHITE/ black (to WHITE/ yellow) wire at the ignition harness that performs the following: key sense, second ignition, starter, and Passlock resistance. Call Directed technical service for more information. |
Second Starter | N/A | | |
Ignition | WHITE/ green to dk. blue | + | ign harn or BCM, gray plug, pin B8 |
Notes: The BCM (Body Control Module) is in the passenger kick panel. |
Second Ignition | see starter wire notes | | |
Third Ignition | N/A | | |
Accessory | WHITE/ red to brown | + | ign harn or BCM, gray plug, pin B7 |
Second Accessory | N/A | | |
Keysense | see starter wire notes | | |
Power Lock | lt. blue | - | either kick or BCM, blk plg, pin A11 |
Power Unlock | dk. blue | - | either kick, door harness |
Notes: To unlock just the driver door use white (-) at the BCM, black plug, pin A12.The BCM (Body Control Module) is in the passenger kick panel. |
Lock Motor | gray | 5wi | lock switch in driver door |
Unlock Motor | tan | 5wi | lock switch in driver door |
Parking Lights+ | brown | + | BCM, black plug, pin A48 |
Parking Lights- | BROWN / white | - | switch or BCM, gray plug, pin A7 |
Hazards | white | - | switch or BCM, gray plug, pin A48 |
Turn Signal(L) | lt. blue (F), yellow (R) | + | BCM, black plug, pins A3, B1 |
Turn Signal(R) | dk. blue (F), dk. green (R) | + | BCM, black plug, pins A19, B2 |
Reverse Light | lt. green | + | inside mirror or fuse box under hood |
Door Trigger | see notes | - | BCM, black plug |
Notes: The driver door trigger is gray/black in pin A32, the passenger door is lt. GREEN/ black in pin A38, the left rear door is lt. blue/black in pin A44, and the right rear door is BLACK/ white in pin A39. Use all four and diode isolate each.The BCM (Body Control Module) is in the passenger kick panel. |
Dome Supervision | white | - | BCM, black plug, pin A46 |
Trunk/Hatch Pin | N/A | | |
Hood Pin | N/A | | |
Trunk/Hatch Release | N/A | | |
Power Sliding Door | N/A | | |
Factory Alarm Arm | | | |
Factory Alarm Disarm | | | |
Disarm No Unlock | | | |
Tachometer | NOT pink or black | ac | any ignition coil or injector |
Wait to start | N/A | | |
Brake Wire | lt. blue | + | brake pedal switch |
Parking Brake | lt. blue | - | switch or BCM, black plug, pin A31 |
Horn Trigger | green to black | - | column or BCM, gray plug, pin A25 |
Memory Seat 1 | N/A | | |
Memory Seat 2 | N/A | | |
Memory Seat 3 | N/A | | |
