How is the disarm and arm working?
ivanca
Member - Posts: 34
Posted: November 08, 2004 at 7:36 PM / IP Logged
When does it send out pulse? When does it stop send pulse?
auex
Platinum - Posts: 5,041
Posted: November 08, 2004 at 7:45 PM / IP Logged
Sorry, but what the hell are you talking about?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Teken
Gold - Posts: 1,492
Posted: November 08, 2004 at 7:59 PM / IP Logged
LMFAO . . .
Knowledge is power. But only if you apply that knowledge in a positive way, which promotes positive results in others.
EVIL Teken . . .
ivanca
Member - Posts: 34
Posted: November 08, 2004 at 8:03 PM / IP Logged
Some remote start alarm have the disarm/ arm wire output to disarm/arm the factory alarm. But I just want to know the working orders. Such as, before cranking, disarm, after starting, rearm....etc.
auex
Posted: November 08, 2004 at 8:07 PM / IP Logged
How about a specific alarm? Also your original post said nothing about remote start.
A remote start will "generally" send a disarm pulse before it powers the ignition. It will also send a rearm pulse after the remote start times out.
ivanca
Member - Posts: 34
Posted: November 08, 2004 at 8:14 PM / IP Logged
Thanks. So nothing happend between canking and start times out?
I check compustar's manual that it says rearm 1 pulse after starter, what does it mean?
fbird08
Copper - Posts: 90
Posted: November 09, 2004 at 1:58 AM / IP Logged
Generally the disarm pulses right before the car remote starts and when you hit the unlock button. The arm will either pulse right after the car remote starts or right after the remote starter is shut down and when you hit the lock button.
Money is just paper
Power is fleeting
But your word is everything,
If your word means nothing,
You are nothing...think about it
ivanca
Member - Posts: 34
Posted: November 09, 2004 at 11:10 AM / IP Logged
If the rearm sends signal to OEM Alarm between remote starting and shutting down, the factory alarm should go off. Because the factory alarm might detect the KEY ON.
fbird08
Copper - Posts: 90
Posted: November 09, 2004 at 8:53 PM / IP Logged
That is true ivanca but this guy just wanted to know what the wires do. Some remote starters can be programed to lock the doors right after startup because in some cars the doors unlock when you disarm the factory alarm. The factory arm wire is used to relock the doors.
Money is just paper
Power is fleeting
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
