2001 monte carlo remote start
Welcome Guest :)
danh0ward
Member -
Posted: December 14, 2004 at 12:41 PM / IP Logged
I need a rs diagram for a 2001 chev monte carlo thanks
Dan Howard
rudbwoy69camaro
Silver -
Posted: December 14, 2004 at 2:23 PM / IP Logged
2001 Chevrolet Monte Carlo Item | Wire Color | Polarity | Wire Location |
12V | red | + | ignition harness *1 |
STARTER | yellow | + | ignition harness *1 |
IGNITION | pink | + | ignition harness *1 |
ACCESSORY | orange | + | ignition harness *1 |
SECOND ACCESSORY | green | + | ignition harness *1 |
TACHOMETER | white | | ignition coil |
POWER LOCK | ORANGE / black | *2 | gray 24-pin plug @ BCM *3 |
POWER UNLOCK | same wire as lock | - | gray 24-pin plug @ BCM *3 |
PARKING LIGHTS + | do NOT use | | |
PARKING LIGHTS - | white *8 | | pink 24-pin plug @ BCM *3 |
DOOR TRIGGER | *5 | - | gray 16-pin plug @ BCM *3 |
HEADLIGHTS | yellow | - | gray 24-pin plug @ BCM *3 |
WIPERS | | | |
LF WINDOW UP/DN | blue - brown | A | drivers window switch |
RF WINDOW UP/DN | lt. blu - tan | A | drivers door harness |
LR WINDOW UP/DN | green - purple | A | drivers door harness |
RR WINDOW UP/DN | lt. grn - purple | A | drivers door harness |
TRUNK/HATCH PIN | RED / black | - | gray 24-pin plug @ BCM *3 |
HOOD PIN | none | | |
TRUNK/HATCH RELEASE | black | - | release switch |
FACTORY ALARM ARM | none | | |
FACTORY ALARM DISARM | lt green | - | gray 16-pin plug @ BCM *3 |
HORN TRIGGER | black *6 | - | steering column |
BRAKE WIRE | white | + | brake switch |
LOCK MOTOR | *4 | | |
UNLOCK MOTOR | *4 | | |
DISARM DEFEAT | *4 | | |
DISARM NO UNLOCK | none | | |
DOME SUPERVISION | use door trigger | | |
SPEED SENSE | green | | gray 16-pin plug @ BCM *3 |
SUN ROOF OPEN/CLOSE | | | |
SUN ROOF LIMIT | | | |
LF SPEAKER | none | | |
RF SPEAKER | none | | |
LR SPEAKER | none | | |
RR SPEAKER | none | | |
RADIO 12V | none | | |
RADIO GROUND | none | | |
RADIO SWITCH | none | | |
RADIO ILLUMINATE | none | | |
POWER ANTENNA | none | | |
Notes: | NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The ignition harness is located far right of the steering column, behind the ignition switch. *2 Lock and unlock use the same wire. Lock requires a negative trigger with a 470 ohm resistor in-line. Unlock is negative trigger. Must use relays. *3 The BCM is located above the brake pedal. It is a plastic box with three plugs that face the firewall. *4 Installation of factory keyless upgrade alarm is not recommended on this vehicle because the door lock motor wires rest at approximately 7 volts. *5 The drivers door trigger wire is blue. Blue/white will catch the passenger door. Use both wires and diode isolate each. *6 Horn can also be found at the black plug with a blue insert above the gas pedal. *7 This wire must be powered as an accessory wire. If powered as an 2nd ignition the car will not crank. *8 Must isolate this wire from the BCM when doing remote start to avoid 'service engine soon' light. See directfax document #1600 for wiring information. |
Saturday, July 12, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
