1982 Firebird, alarm advice
82Firebird
Member - Posts: 17
Posted: April 24, 2005 at 2:23 PM / IP Logged
I want to hook up an alarm into my 1982 Firebird. The options I want besides the alarm itselft, is keyless entry and proximity sensor. I went to a local stero shop and they seemed to recommend the Viper 3101V with the addition of a DEI proximity sensor. Is this a good system? Other recommendations? They gave me a quote of $404 installed.
I found this same alarm online for $149 and the proximity sensor for around $40.
How hard would this to be to hook up myself? What is really involoved? My only install experience was when my dad and I put a remote start/keyless system in an old Bonneville I had. I have done many heaunit, amplifier, and speaker installs however from what I understand installing an alarm might be a whole new ball game.   1982 Firebird, alarm advice - Last Post -- posted image.
swamprat323
Gold - Posts: 1,335
Posted: April 24, 2005 at 2:33 PM / IP Logged
if you put in a alarm remote start b4 and had no problems then i say you can put in the alarm.
bretbowman
Copper - Posts: 156
Posted: April 24, 2005 at 10:54 PM / IP Logged
You can do it.  Have some confidence.  Installing alarms and remote start systems is really a no brainer on older cars.  It does get more complicated on newer cars, but on an '82, I'd say go ahead.  If you get the wiring diagrams and take the time to find and test all your wires, it's really a cake walk.  Keep in mind, it's MUCH cheaper if you install it yourself too!
If you want a challenge, try troubleshooting a 8 way processor SQL database cluster server running Window 2000 Advanced server software that is a live site for AT&T wireless in Seattle, WA via a remote KVM over IP with a cruddy video connection that has very slow response time and you cannot reboot the server because the system may not come back up.  Since you'd be 2,000 miles away in Cincinnati, OH, you would have to call remote hands to reboot the computer for you if you happen to shut it down.  And the response time of the datacenter technician is not as fast as you'd be praying it was because the customer is very demanding!   That is a bit harder...   just only a bit.  1982 Firebird, alarm advice - Last Post -- posted image.
Good luck with the install!
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
henriNguyen
Posted: April 25, 2005 at 6:23 PM / IP Logged
go  for it
my first alarm install was Compustart 2way  to my 2000 infinity qx4
gess how long this take me??
2 weeks
you can do this
good luck
gcorrea
Silver - Posts: 436
Posted: April 26, 2005 at 3:13 PM / IP Logged
give it a shot studt your cars wiring diagrams as well as the alarms. understand what each wire does and where it goes. and dont forget you have the12volt.com behind you. just ask.
gcorrea
82Firebird
Member - Posts: 17
Posted: April 26, 2005 at 6:40 PM / IP Logged
Thanks guys. I'm going to go ahead and give it a shot! If I need any help I'll be sure to let you know.
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
