1996 monte carlo, alarm/remote start
jonchos
Copper - Posts: 256
Posted: July 11, 2005 at 1:27 PM / IP Logged
Thank you in your info, but doesn't the wiring diagram in the12volt.com says that the car has three different ignitions? also in the directechs.com webpage says the car has a second ignition, I do not see any secondary accesory wire. Regarding the color of the wire, purple is the wire that goes to the second ignition. what is second ignition anyway? thank you.
jonchos
Copper - Posts: 256
Posted: July 11, 2005 at 1:33 PM / IP Logged
I have installed a valet 561t on a 96 chevrolet monte carlo. In the wiring diagram for this car at directechs.com explains that the car has a second ignition, I did not install the second ignition from my remote start to the second ignition on the car, is this a problem? or will it cause a problem later? my car starts fine, the only thing that does not work properly is the ac, it turns on, but the air wont come out from the vents, it comes from under the dash and is not cold, any ideas? please help.
TJ92Civic
Copper - Posts: 161
Posted: July 11, 2005 at 1:54 PM / IP Logged
Hook up the second ignition.  Your heat will probably not work while remote started either.
jonchos
Copper - Posts: 256
Posted: July 11, 2005 at 2:19 PM / IP Logged
so you think this why the ac is not working? or the stereo?
Page of 4
Saturday, July 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
