2005 Honda CRV remote start wiring?
crv2005
Member - Posts: 34
Posted: November 28, 2005 at 11:08 AM / IP Logged
Hi, I am looking to install a remote starter on a Honda CRV(EX) 2005 and I wanted to know if anyone had the wiring diagram. before I get started, I wanted to know exactly what to look for, also would like to install a passkey since i have a factory alarm.  Suggestions are appriciated.
Thanks2005 Honda CRV remote start wiring? - Last Post -- posted image.
the12volt
Administrator - Posts: 3,959
Posted: November 28, 2005 at 11:17 AM / IP Logged
crv2005
Member - Posts: 34
Posted: December 12, 2005 at 7:16 PM / IP Logged
Thanks,
Besides the remote starter, what other components would i need since i have a factory alarm and one of those keys with a chip insde.  I would want to dis/arm my factory alarm and be able to open/close the door locks and romte start the vehicle with the same remote.
wiretapper
Copper - Posts: 166
Posted: December 12, 2005 at 7:51 PM / IP Logged
Fact. alarm system is a stand alone piece. There's no way around it to use a disarm wire.
You either dump the fact. alarm and install aftermarket alarm/starter combo, or carry two remotes and disarm the system before remote starting. Also the fact. remotes won't work while  the vehicle is running.
I just did an '05 last week that had no fact. alarm. I got lucky.
crv2005
Member - Posts: 34
Posted: December 12, 2005 at 9:30 PM / IP Logged
What are the HODL3 and the PKH3 for?  I am not sure which one to use with the factory alarm when using a remote starter.  I have read on some posts that you need both, but I am not sure for the CRV.2005 Honda CRV remote start wiring? - Last Post -- posted image.
wiretapper
Copper - Posts: 166
Posted: December 12, 2005 at 9:39 PM / IP Logged
Not sure about either of those, but the DEI 555HW woks just fine for the transponder bypass.
navigator2004
Posted: December 17, 2005 at 11:35 PM / IP Logged
How do you install a Remote Start Add-on to a Factory Keyless Entry System?  I have a 04 Navigator and a Startnr2 Remote Start with the PKF3 Bypass.  If I ground the Trigger, it starts the vehicle; however, I can't find a Negative Pulse from the Keyless Entry that will allow me to Remote Start the Vehicle.
Thanks,
Kenny
Navigator2004
gus1
Gold - Posts: 1,013
Posted: December 18, 2005 at 12:59 AM / IP Logged
Yo... wiretapper...
Factory disarm is in the door.... test with key in door. At the Driver's door module. The whole "carry 2 remotes" BS is only for installers too lazy to go get the proper arm and disarm wires.
555HW doesen;t work as nicely as the 556H. The HODL is a doorlock interface..... doorlocks are negative in the kick (think Civic), and the DL piece will also do disarm I believe. The PKH3 should do the transponder bypass.
Gus
crv2005
Member - Posts: 34
Posted: December 18, 2005 at 7:37 AM / IP Logged
How about the wipers, how can I cut the power when the remote starter is activated. I do not want to burn the motor.
gus1
Gold - Posts: 1,013
Posted: December 18, 2005 at 8:33 AM / IP Logged
Find the wiper motor, use a relay.
You need to power up both acessories (WHITE/ red, and I believe yellow). Not sure which one the wipers live on, and what else lives on that Acessory circuit... but if it is that much of a concern, find the wiper motor, and interrupt the power to it using a relay running off of a negative second ignition output.
Gus
