2004 chevy truck complete system
superboy95
Member - Posts: 17
Posted: December 12, 2005 at 3:53 PM / IP Logged
The stock speakers have stock wire running to them.  Instead of threading wire through the doors they would just hook onto the stock speaker wire.  Think about if you were just replacing the components without amping...you would use the stock speaker wires and run them to the crossover.
I will probably run new wire.  Although the tables i've found say the stock wire should handle <90rms.  Just wondering if anyone else had experience with this and what the results were.
otter
Copper - Posts: 61
Posted: December 12, 2005 at 4:02 PM / IP Logged
okay, yeah, I got it now, did some searching around and found that a lot of people run the stock wires. Whatever is easiest for you I guess, not sure what you would do with the crossovers then though.
superboy95
Member - Posts: 17
Posted: December 12, 2005 at 4:13 PM / IP Logged
Searching around?  On this site or somewhere else?  If here could you please paste links to the threads you found?
Definitely easier to use stock wires, but like I said I don't want to sacrifice sound quality...if it will.
Questions...Questions...That's why i'm here, right?! 2004 chevy truck complete system - Page 2 - Last Post -- posted image.
otter
Copper - Posts: 61
Posted: December 12, 2005 at 6:06 PM / IP Logged
I searched this site, just type in door speakers and you will get a few threads. there is even one that has a calculator for power loss per foot of speaker wire depending on the gauge that you run, good stuff!
dwarren
Posted: December 12, 2005 at 6:11 PM / IP Logged
The factory wiring is fine. You won't hear a difference, but if you want to rewire it go for it.
superboy95 wrote:
3.  Where in the world do i mount those big ugly polk crossovers?  I was told to just wrap them real good with bubble wray and put them inside the doors
Do not do that. Take the time to run new wire to the door. Locate the x-overs up under the dash or kick panels. Don't risk rusting your x-overs out in doors.
superboy95
Member - Posts: 17
Posted: December 12, 2005 at 7:37 PM / IP Logged
Ok.  Well that definitely means running new wire through the doors (mounting the x-overs in the cab).  Which is what i was trying to avoid.
geepherder
Platinum - Posts: 3,668
Posted: December 13, 2005 at 6:17 PM / IP Logged
You can mount the crossovers to the doors- find a spot where they'll fit between the door panels and the plastic water barrier and screw them in place.
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
