2004 toyota tundra 4 door, locks
hondastunt
Posted: January 09, 2006 at 9:16 PM / IP Logged
2004 toyota tundra 4 door, locks - Last Post -- posted image.
what is used for this child safety door lock system? diode OR resistor
Chris Luongo
Platinum - Posts: 3,746
Posted: January 09, 2006 at 9:19 PM / IP Logged
The black pieces are diodes, but that is not the correct diagram for your Tundra. Hopefully someone will come along with a link to the right one.
mo12v
Posted: January 09, 2006 at 9:30 PM / IP Logged
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1070.pdf
MO
Mike M2
Platinum - Posts: 2,652
Posted: January 10, 2006 at 6:31 AM / IP Logged
That diagram is for the 4 door Tundra only. If it's a 2 door or extended cab you use just negative pulse locks, WHITE/ green for lock and blue/red for unlock with a double pulse.
Mike M2
Tech Manager
CS Dealer Services
mo12v
Posted: January 10, 2006 at 8:51 AM / IP Logged
HMMM............
Topic: 2004 toyota tundra 4 door
MO
Mike M2
Posted: January 10, 2006 at 4:45 PM / IP Logged
2004 toyota tundra 4 door, locks - Last Post -- posted image. oh....yea.......
Mike M2
Tech Manager
CS Dealer Services
hondastunt
Posted: January 11, 2006 at 1:38 AM / IP Logged
what size diodes do I use.
05gt
Silver - Posts: 628
Posted: January 11, 2006 at 2:21 AM / IP Logged
just use the 1 ampers, they will be fine
Mike M2
Posted: January 11, 2006 at 6:33 AM / IP Logged
Also, you can use 12V from inside the door, you don't need to run it. Use the large blue wire on the back of the switch mod....
Mike M2
Tech Manager
CS Dealer Services
