Interlok troubles
dangerranger96
Copper - Posts: 163
Posted: July 28, 2006 at 7:06 PM / IP Logged
I am trying to rewire my truck, and I have bought a interlok power ring and i cant figure out how to connect the wire to the connector
97 F150, Sony CDX-M630, Sony XM-2165GTX, JL Audio 12W3D2, Planet Audio VX-602, Memphis 15-MC5.7
Yeah it's a mutt, but mutts make the best dogs!
KarTuneMan
Platinum - Posts: 7,056
Posted: July 29, 2006 at 6:03 PM / IP Logged
What is an interlok power ring?
dangerranger96
Copper - Posts: 163
Posted: July 29, 2006 at 6:13 PM / IP Logged
Interlok troubles - Last Post -- posted image.
This is what im using... i just dont have any clue on how to use it.
Flakman
Copper - Posts: 365
Posted: July 29, 2006 at 6:58 PM / IP Logged
I believe your interloks work by unscrewing the piece on the bottom, threading the bare wire through the bottom ring into the upper portion and then screwing the bottom ring back on.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
dangerranger96
Copper - Posts: 163
Posted: July 29, 2006 at 6:59 PM / IP Logged
i thought that would be it... but i did that and the wire is still loose
haemphyst
Platinum - Posts: 5,059
Posted: July 29, 2006 at 7:11 PM / IP Logged
No instructions? Here's a case of RTFM... (and that's SUPPOSED to be sarcastic... not a slam.)
If still loose, then I'd say you got the wrong size for the wire you have.
dangerranger96
Copper - Posts: 163
Posted: July 29, 2006 at 7:22 PM / IP Logged
4 gauge terminal for 4 gauge wire... sizes are correct
austincustoms
Copper - Posts: 232
Posted: July 29, 2006 at 10:11 PM / IP Logged
Did you try adjusting it with your poundometer?  Maybe solder it?
KarTuneMan
Posted: July 29, 2006 at 10:53 PM / IP Logged
poundometer....the things you learn on the 12Volt. Interlok troubles - Last Post -- posted image.
dangerranger96. try stripping back some more of the cable? you need enough to fold the wire over on the sleeve. Then feed it up into the ring and tighten!
dangerranger96
Copper - Posts: 163
Posted: July 29, 2006 at 11:19 PM / IP Logged
thanks tune man... that worked, unfortunately, after i got that working, i found out the terminal was too big to connect to the post terminal... so i had to go with a lil crimp on piece... oh well
