00 Civic Sedan Front Speaker
borked
Member - Posts: 15
Posted: August 03, 2006 at 4:10 AM / IP Logged
Anyone here have any experience wiring new front speakers in a 00 civic sedan? The boot where youd normally feed the wire from the door speaker to the amp is alot deeper set than ive ran into any other car.
Do I have to take apart the entire dash/glovebox too to get access to this?
djfearny2
Silver - Posts: 810
Posted: August 03, 2006 at 7:17 AM / IP Logged
if the boot is open you can use a small non pointed fish tape to run wires. i have used everything from old antennas. Large cable ties. fish tapes. large screw drivers. each application requires a different technic and well there has never been a car i could not get wires through the boot. evn cars that have molex plugs through the door. so good luck i hope i have given you some guidance. also your dont need super heavy guage speaker wire so you should be able to get through the boot.
Jon
Installer/Help Technician
---coral springs florida---
borked
Member - Posts: 15
Posted: August 04, 2006 at 12:25 AM / IP Logged
Im using 14 gauge, a little big for 60w rms but if it is a problem i can go down to 16g i suppose. The problem is the boot is set so far back its almost like its coming through the engine compartment I cant seem to get anything back there far enough to run any kind of object through there, even if i could I have no idea where it comes out being that its set so far back.
geepherder
Platinum - Posts: 3,668
Posted: August 04, 2006 at 7:01 AM / IP Logged
You mean so far back in the fender well?  Have you removed the fender?  That should do the trick.
Platinum - Posts: 12,488
Posted: August 04, 2006 at 9:49 AM / IP Logged
Pull the boot off from both the door and the body fish the wires through and get the boot wet to reinstall the boot back onto the car and the door. Removing the fender will help but if you have small enough hands, you shouldn't need to remove the fender.
borked
Member - Posts: 15
Posted: August 07, 2006 at 2:26 AM / IP Logged
figured out why i wasnt able to feed any wire through, upon closer inspection and removing some plastic housing. its a molex connector. so im gonna try this tut. i found on here and hopefully it works. such a pain...
KarTuneMan
Platinum - Posts: 7,056
Posted: August 08, 2006 at 1:01 AM / IP Logged
Your kidding.....RIGHT ???00 Civic Sedan Front Speaker - Last Post -- posted image.
geepherder
Posted: August 12, 2006 at 2:30 PM / IP Logged
Actually, no.  I've never done it on that particular car, but on my car it made all the difference in the world.
