2001 Tahoe, Viper 971XV, DEI 457G
jorgefdz
Copper - Posts: 99
Posted: December 26, 2006 at 2:11 AM / IP Logged
Hi,
   I dont know how to install my DEI 457G. My 2001 Tahoe has a passlock with an orange tubing with 2 white wires and I dont know how wire them to the 457G module.
MAIN HARNESS
Black      to GRound
Red        to 12V constant
Violet     to Violet of diagnostic plug
Blue white to Blue White (status output)
IGNITION HARNESS
White yellow   - Not used
Pinsk/Black    - I dont know where to conect it.
Pink           - I dont know where to conect it.
I appreciate your help. Thanks so much.
Jorge
j.f.l.l.
Mike M2
Platinum - Posts: 2,652
Posted: December 26, 2006 at 6:51 AM / IP Logged
All you use are the 4 wires on the main harness, don't use the 3 wire harness at all on a Tahoe.
Mike M2
Tech Manager
CS Dealer Services
kgerry
Platinum - Posts: 3,455
Posted: December 26, 2006 at 10:18 AM / IP Logged
plus the orange tubing is not your passlock wires and you dont need to worry about where they are....   the 457G will shut off the passlock via data without needing to go to the actual passlock wires.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
jorgefdz
Copper - Posts: 99
Posted: December 26, 2006 at 12:09 PM / IP Logged
Thanks a lot Mike M2 and Kgerry.
I have another question... Do I need to Program the 457G anyway?
Thanks.
j.f.l.l.
kgerry
Posted: December 26, 2006 at 12:21 PM / IP Logged
yes... it still has to learn the R code.... but programming is easier than with the 1700 because you dont need to select a specific platform... it works with all platforms....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
jorgefdz
Copper - Posts: 99
Posted: December 26, 2006 at 9:47 PM / IP Logged
Thanks a lot Kgerry.
It works perfect and its very easy..
Thanks for all your help.
j.f.l.l.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
