subs cutting out
kingkongaudi
Posted: January 23, 2007 at 9:04 PM / IP Logged
aight well i have 2 dvc 4ohm mtx 5500's running off an alpine mrp-350 amp with an alpine headunit..the subs sound great with the bass at -7 (lowest setting) and sub control at +8(goes to 15) and the volume at around 20(not even 75% of the max)..as soon as i turn the volume or settings past any of that, the subs cut out and i have to turn off my headunit and turn it back on..i dont know if thats good or bad or what i need to fix it but any advice would help
DYohn
Platinum - Posts: 10,741
Posted: January 23, 2007 at 9:20 PM / IP Logged
How are the subs wired?  How is the gain set?
coppellstereo
Silver - Posts: 785
Posted: January 23, 2007 at 9:47 PM / IP Logged
turn bass to zero and sub to zero - then re-set your amp gain.
then see what happens
kingkongaudi
Posted: January 24, 2007 at 5:07 PM / IP Logged
yeah well i did that and now my amp wont even turn on...i believe i have the subs wired to 2 ohms but my friend said that i have them wired wrong so the amp cant work with correctly..but first i have to figure out why the amp wont turn on now...the fuses are fine and i disconnected it from the subs..what else should i do?
KarTuneMan
Platinum - Posts: 7,056
Posted: January 24, 2007 at 6:26 PM / IP Logged
I think your friend is correct.....
coppellstereo
Silver - Posts: 785
Posted: January 24, 2007 at 6:54 PM / IP Logged
disconnect the woofers and see if the amp will turn on and stay on
specialaudio
Copper - Posts: 58
Posted: January 25, 2007 at 5:52 PM / IP Logged
https://www.the12volt.com/caraudio/woofer_configurations.asp
that is more or less the way to wire them.... the subs tho
it could be a gain issue or maybe even a bad ground...
93' Cutlass
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
