2008 f350 avic z2
rolexis
Posted: June 30, 2007 at 10:32 PM / IP Logged
Just picked up my 2008 F350 that came with factory XM satellite and DVD nav. Im replacing with Poineer AVIC-Z2, I have most adapters from crutchfield to install radio.
Few quick Questions, couldnt find much on the 08' ford F350
  • can I use factory NAV antenna already installed?
  • can I use factory XM antenna already installed?
  • Since Factory NAV was installed, does anyone know color code or location of VSS wire for Nav?
  • any other things i should look out for?
Thanks in advance for all you help... found many many great things for my 03' Ford F250
Andrew
Rolexis@aol.com
xxCoOlFoOlxx
integratyper934
Copper - Posts: 150
Posted: July 15, 2007 at 12:54 PM / IP Logged
i would say dont do the z2....do a z1 because you cant bypass the z2. youll regret it later when u have to pull over to do everything
swerks
Copper - Posts: 224
Posted: July 15, 2007 at 10:26 PM / IP Logged
good advice go with a d1 or d3 as they are easily bypassed the nav antenna should work ford nav systems are from pioneer
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
Mike M2
Platinum - Posts: 2,652
Posted: July 16, 2007 at 6:38 AM / IP Logged
A Ford with XM??? Thought they were Sirius....
Mike M2
Tech Manager
CS Dealer Services
jiggalo9481
Posted: September 12, 2007 at 12:55 PM / IP Logged
there is  a swithch located on the avic-z2that will allow you to bypass. how ever it will also void its factory warrenty.
a.t.l
johnmax
Copper - Posts: 131
Posted: September 12, 2007 at 3:11 PM / IP Logged
Actually there is a bypass for the Z2 now. You need to do your homework....
integratyper934
Copper - Posts: 150
Posted: September 12, 2007 at 11:43 PM / IP Logged
you need to check dates ***i posted that months ago when the bypass ws just out. stop trying to make people feel stupid acting like your an install god or something
johnmax
Copper - Posts: 131
Posted: September 13, 2007 at 2:46 PM / IP Logged
Whoa calm down dude. It was directed at the jiggalo poster. Jeez...
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
