2001 Jetta 1.8t Remote Start/Alarm
shadowinfector
Copper - Posts: 199
Posted: August 20, 2007 at 11:30 AM / IP Logged
anyone?
swerks
Copper - Posts: 224
Posted: August 20, 2007 at 5:37 PM / IP Logged
you can get tach behind the cluster GREEN/ brown in blue plug
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
gus1
Gold - Posts: 1,013
Posted: August 23, 2007 at 1:00 PM / IP Logged
Better off heading to an injector on the 1.8T.......... right on top of the motor. Or a coil pack. Close to injectors.......
Getting at the ECU is not that bad, remove pollen filter cover, pull wiper arms, carefully remove the entire lower cowl at the bottom of windshield. Takes like 5 min to do. Pulling the cluster isn't that fun at all.......
shadowinfector
Copper - Posts: 199
Posted: September 02, 2007 at 8:54 AM / IP Logged
can anyone confirm that the DB-VWDL will work on a jetta 1.8t 2001? thanx
shadowinfector
Copper - Posts: 199
Posted: September 03, 2007 at 10:52 PM / IP Logged
okay i hooked up everything but i am having a problem with the key ring for the bypass. for sum reason it is not starting...i tried leaving the key in the cylinder and when it starts it sound like its mis-sfiring or sumtin...missing a coil or sumtin....doesn sound like it usually does when u start it with the key itself...please help....
Page of 3
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
