viper 5900, 08 honda civic si
dhantiflag
Posted: November 07, 2007 at 3:11 PM / IP Logged
im wondering exactly what this does and how it works, i am considering installing a remote start on a 2008 civic SI, i want to do it the right way and i need all the information i can come about it on.
Thanks!
Platinum - Posts: 13,726
Posted: November 07, 2007 at 8:26 PM / IP Logged
There are alarms with built in remote start modules that are MADE for manual transmission vehicles.   I am sure others here can give you make and model numbers.
enice
Silver - Posts: 857
Posted: November 07, 2007 at 8:36 PM / IP Logged
If you like DEI products then its fairly straight forward.  If you would like the manual I may send it to you by email.  just pm me with your email address.
07mustanggt
Copper - Posts: 89
Posted: November 07, 2007 at 10:42 PM / IP Logged
The 689m is used the same as the compustar alarms for manual trans cars. Basically you have to go thru a sequence of events to prep the car for r/s. Take key out of ignition, car stays running, put it in neutral, pull e brake, open door, then close door. Car now shuts off. Now it is prepped for r/s. You have to do this sequence every time you turn off your car.
dhantiflag
Posted: November 23, 2007 at 4:16 PM / IP Logged
**EDIT** duplicate topics merged
what all do i need with this remote start system?
i getting DEI neutral saftey modul, do i need anything else?
dre187
Copper - Posts: 129
Posted: November 23, 2007 at 7:27 PM / IP Logged
im assuming you mean an 08' honda civic. you would also need something to interface the immobilizer system. DEI's 556U is ok and requires you to loose a key. you can also useone of their XK modules. i believe its XK04 or 05 ( i forget off the top of my head) but this allows you to keep both keys. give specific info on the vehicle for future so people dont have to guess
