adding remote start 02 tahoe oem keyless
S.I.Autosports
Copper - Posts: 98
Posted: January 22, 2008 at 5:22 AM / IP Logged
I am going to be adding a remote start to the factory keyless on a 02 Tahoe.  Anyone know which wire I will need to interupt so the keyless will work while the truck is remote started?  The ignition wire to the BCM?  Anyone know the color/pin # ?
rudydapimp
Copper - Posts: 390
Posted: January 22, 2008 at 6:51 AM / IP Logged
im pretty sure that most Gm's transmitters will work while the truck is running.
Twelvoltz
Platinum - Posts: 2,384
Posted: January 22, 2008 at 9:45 AM / IP Logged
As rudydapump mentioned, your keyless will work fine when running under the RS. No need to cut anything.
S.I.Autosports
Copper - Posts: 98
Posted: January 23, 2008 at 3:45 AM / IP Logged
Thanks guys!  I was thinking most newer cars won't let you use the remote if the car is running.
Monday, June 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
