clutch bypass for 2007 hyundai accent gs
Mike_89gts
Member - Posts: 42
Posted: February 04, 2008 at 8:56 PM / IP Logged
Hello everybody!
Anyone know what kind of clutch switching system I have
in my 2007 Hyundai Accent GS?
Which wire am I connecting my "Ground Out
When Running" wire to?
Thanks a bunch in advance folks!
Mike
chadwa2003
Copper - Posts: 353
Posted: February 04, 2008 at 9:05 PM / IP Logged
What kind of system are you installing
Mike_89gts
Member - Posts: 42
Posted: February 05, 2008 at 6:29 AM / IP Logged
It's a crappy tire Prostart CT-3260 for manual transmission.
Thanks a bunch! - Mike
KarTuneMan
Platinum - Posts: 7,056
Posted: February 05, 2008 at 9:08 AM / IP Logged
Send a negative start signal to the BLACK/ orange at the clutch switch. You also need to connect the posative start at the harness.
Mike_89gts
Member - Posts: 42
Posted: February 05, 2008 at 10:08 AM / IP Logged
Sorry KarTuneMan... you lost me there!
So, my GOWR go to BLACK/ orange @ clutch but what is that your saying about about positive at harness?  Are you saying I've got to connect 2 clutch wires to my RS unit??
Thanks,
Mike
tedmond
Gold - Posts: 4,610
Posted: February 05, 2008 at 2:16 PM / IP Logged
no, send a negative start signal (on the prostart set it for 5th relay ignition 3 output (-) ) then also connect the 12v start wire at ignition harness.
chadwa2003
Copper - Posts: 353
Posted: February 05, 2008 at 2:25 PM / IP Logged
You can use the gwr wire that will be okay. But if you have a neg start pulse that would be better but both will work fine
Mike_89gts
Member - Posts: 42
Posted: February 05, 2008 at 8:42 PM / IP Logged
ok guys... I'm just a little slow.
So are you saying I have a positive clutch and
my starter wire from my RS has to be hooked up to
the clutch. And if that's the case, I'm assuming
the RS starter wire does NOT get hooked up to
my car's ignition harness.
OR
Are you just stating that... (like it says in the manual)
to hook up the RS starter output wire to starter wire in
my ignition harness.
Have I got 1 or 2 connections to make at my clutch?
Bypassing the clutch is my only question... everything
else is good to go.
Sorry for the confusion folks... just need it in
layman's terms.
Thanks again!
Mike
chadwa2003
Copper - Posts: 353
Posted: February 05, 2008 at 9:42 PM / IP Logged
White wire from prostart to BLACK/ orange at clutch switch and purple from prostart to white wire in the ignition harness
Mike_89gts
Member - Posts: 42
Posted: February 06, 2008 at 8:06 AM / IP Logged
Perfect - thanks folks.  Truly appreciate it!
Mike
Page of 3
Saturday, November 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
