viper remote start, 08 honda element
devilchrist1
Member - Posts: 29
Posted: August 22, 2008 at 4:12 PM / IP Logged
Hi,
Like the subject, I need a wiring diagram for 07/08 element EX.  Planning on install viper5900 with remote start.
DIY guy, can't learn if you never try
Platinum - Posts: 13,725
Posted: August 22, 2008 at 8:08 PM / IP Logged
viper remote start, 08 honda element -- posted image.Battery WHITE (+) IGNITION SWITCH HARNESS
viper remote start, 08 honda element -- posted image.Ignition 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
viper remote start, 08 honda element -- posted image.Ignition 2 BLACK/ RED (+) IGNITION SWITCH HARNESS
viper remote start, 08 honda element -- posted image.Accessory 1 WHITE/ RED (+) IGNITION SWITCH HARNESS
viper remote start, 08 honda element -- posted image.Starter 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
viper remote start, 08 honda element -- posted image.Anti-Theft Type UNIVERSAL IMMOBILIZER
viper remote start, 08 honda element -- posted image.Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
viper remote start, 08 honda element -- posted image.Key Sense RED / WHITE (-) IGNITION SWITCH HARNESS viper remote start, 08 honda element -- posted image.
viper remote start, 08 honda element -- posted image.Tachometer BLUE (AC) AT ECM MODULE BEHIND GLOVEBOX
viper remote start, 08 honda element -- posted image.Speed Sense BLUE/WHITE (AC) AT ECM MODULE BEHIND GLOVEBOX  viper remote start, 08 honda element -- posted image.
viper remote start, 08 honda element -- posted image.Parking Lights RED / YELLOW (+) AT UNDER DASH FUSEBOX
viper remote start, 08 honda element -- posted image.Low Crr. Pk Lights BLUE (-) IN GREEN PLUG NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
viper remote start, 08 honda element -- posted image.Brake Lights WHITE/ BLACK (+) AT SWITCH ABOVE PEDAL
viper remote start, 08 honda element -- posted image.Reverse Lights GREEN/ BLACK (+) AT FUSE PANEL UNDER STEERING COLUMN
viper remote start, 08 honda element -- posted image.Horn ORANGE (-) IN GREEN PLUG NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
viper remote start, 08 honda element -- posted image.Alarm Indicator WHITE (+) IN GREEN PLUG NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
devilchrist1
Member - Posts: 29
Posted: August 25, 2008 at 9:25 AM / IP Logged
Thanks in advance.
going to be installing Viper 5900 w/ remote start
was wondering if the wiring is same as 2003 element?
ckeeler
Gold - Posts: 1,461
Posted: August 26, 2008 at 4:34 PM / IP Logged
the wiring on the 08 is different. here you go.
12 VOLT CONSTANT
WHITE (+)
 STARTER BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLACK/ RED (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 WHITE/ RED (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) BLUE (-)  @ FACTORY ALARM Plug, See NOTE *2
 PARKING LIGHTS ( + ) RED / BLACK (+)  @ BACK OF FUSEBOX
 POWER LOCK WHITE/ BLUE (TYPE B)  IN DRIVER KICK PANEL at DOOR HARNESS
 POWER UNLOCK WHITE/ GREEN (TYPE B)  IN DRIVERS KICK PANEL, at DOOR HARNESS
 LOCK MOTOR WIRE YELLOW/BLACK (+)  IN DRIVERS KICK PANEL
 DOOR TRIGGER GREEN (-) and GRAY/BLACK (-) Use both, See NOTE *1  @ FACTORY ALARM PLUG, See NOTE *2
 DOMELIGHT SUPERVISION GREEN/ RED (-), Requires Part #775 Relay  BACK OF FUSEBOX
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN ORANGE (-)  @ STEERING COLUMN HARNESS
 TACH BLUE  @ ECM/PCM, BEHIND GLOVEBOX, PIN E25
 WAIT TO START LIGHT N/A
 BRAKE WHITE/ BLACK (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY, Standard on all Models  TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
 NOTE *1 THE DRIVERS DOOR TRIGGER IS GREEN (-) AND THE PASSENGER DOOR TRIGGER IS GRAY/BLACK (-). WHEN CONNECTING TO AN ALARM SYSTEM, USE BOTH DOOR TRIGGER WIRES AND DIODE ISOLATE, See DIAGRAM
NOTE *2 THE FACTORY ALARM PLUG IS LOCATED LEFT OF THE STEERING COLUMN IN A GREEN PLUG.
devilchrist1
Member - Posts: 29
Posted: August 27, 2008 at 4:52 PM / IP Logged
And a couple of questions regarding install.
All this time I've been fumbling my way through 571vx install manual thinking it was 791vx.. when a common sense should have told me, there's no antena input, no shock sensor input, etc.. that it was not the correct manual.
But alas. I have found a page of Quick wiring reference guide.
Any help regarding the manul would be much apprciated.
Thanks in advance.
Posted: August 27, 2008 at 9:22 PM / IP Logged
devilchrist1
Member - Posts: 29
Posted: August 28, 2008 at 12:14 AM / IP Logged
I'm confused on these 4 wires.   I understand the Power lock/unlocks are for the doors. but what's the Lock/Unlock  Motor?
DIRECTWIRE™ WIRING INFORMATION - HONDA / ELEMENT / 2004 / Remote Start
Power Lock WHITE/ blue   -   driver kick, door harness
Power Unlock WHITE/ green   -   driver kick, door harness
Lock Motor yellow/black   5wi DKP or back of fuse box, top left
Unlock Motor YELLOW /GREEN   5wi DKP or back of fuse box, top left
devilchrist1
Member - Posts: 29
Posted: August 28, 2008 at 12:22 AM / IP Logged
thank you so much.. cleared up much of the confusion
is these connections required?
relay key switch interface
RED / WHITE (+) 12V input  Connection for high current outputs.
H1/1 ORANGE (-) ground-when-armed output  This wire supplies a (-)500 mA ground as long as the system is armed. This output ceases as soon as the system is disarmed. The orange wire may be wired to an optional Directed Electronics 8618 starter kill relay.
ckeeler
Gold - Posts: 1,461
Posted: August 29, 2008 at 3:08 PM / IP Logged
these are the wires that go directly to the motor in the driver side door. in nearly all cases these are not used. the info is provided though, for installs that will have driver door priority but do not have a wire or double pulse feature in the vehicle to actvate that feaure.
devilchrist1
Member - Posts: 29
Posted: October 01, 2008 at 1:52 PM / IP Logged
I testing the install of alarm viper 5900 on my 2008 element.
after locking myself in the car and arming the alarm I can still use the key to start the engine.  Is this normal?  If I dont' want this to happen do I need to add additional relay?
Install manual says I can add a starter kill relay DEI 8618.  is this what I have to do in order to prevent the above?
Page of 3
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
