98 Hombre/S10 Passlock 2
canter6
Member - Posts: 16
Posted: October 10, 2008 at 8:02 AM / IP Logged
98 Hombre/S10 Passlock 2 - Page 2 -- posted image.
canter6
Member - Posts: 16
Posted: October 10, 2008 at 8:04 AM / IP Logged
canter6
Member - Posts: 16
Posted: October 10, 2008 at 8:06 AM / IP Logged
also i found this... it says shock sensor,... doubt its part of my problem.. but hell it cant hurt to get the professionals opinion.
canter6
Member - Posts: 16
Posted: October 10, 2008 at 8:08 AM / IP Logged
ckeeler
Gold - Posts: 1,461
Posted: October 10, 2008 at 9:03 AM / IP Logged
here is the factory wiring. im starting to wonder if after you put this all back together like original, and it still wont start, if maybe you dont really have a bad fuel pump.....???
12 VOLT CONSTANT
RED (+)
IGNITION SWITCH HARNESS
 STARTER YELLOW(+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 PINK(+) IGNITION SWITCH HARNESS
 IGNITION 2 WHITE (+) See NOTE *4 IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 ORANGE (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) WHITE (-)  @ BCM, IN LIGHT BLUE PLUG, See NOTE *1
 PARKING LIGHTS ( + ) BROWN (+)  @ BCM, IN LIGHT BLUE PLUG, See NOTE *1
 POWER LOCK LIGHT BLUE (TYPE A)  @ BCM, IN BROWN PLUG, See NOTE *1
 POWER UNLOCK WHITE (TYPE A)  @ BCM, IN BROWN PLUG, See NOTE *1
 LOCK MOTOR WIRE GRAY (+)  IN DRIVERS DOOR HARNESS
 DOOR TRIGGER See NOTE *2  @ BCM, See NOTE *1
 DOMELIGHT SUPERVISION TAN (-)  @ BCM, See NOTE *1
 TRUNK RELEASE BLACK (-)  @ BCM, IN PURPLE PLUG, See NOTE *1
 SLIDING POWER DOOR N/A
 HORN BLACK (-)  @ BCM, IN PURPLE PLUG, See NOTE *1
 TACH WHITE  @ PCM, See NOTE *3
 WAIT TO START LIGHT N/A
 BRAKE WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  LIGHT GREEN (-)  @ BCM, IN PURPLE PLUG, See NOTE *1
 ANTI-THEFT YELLOW (+), ORANGE / BLACK (-) and RED / WHITE (Not used)  GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
canter6
Member - Posts: 16
Posted: October 10, 2008 at 10:21 AM / IP Logged
thanks, ive got that sheet...
if you look at the pic in the firast post of this page (page 2) you will see a blue and orange wire coming out from behind where the BCM is located.. i can find where that was supposed to be from.. or where it was cut from..
the reason i believe it to be passlock related is the vehicle started up perfectly and ran everytime, BEFORE the battery died..
which is why i traced the yellow data wire from the cylinder down the column.. and couldnt find where there had been a break in it.. (aside from the one i put in last last in an attempt to tie in resistors..
i have gotten the truck to start and stay running twice now ... once drove it around the neighborhood... and shut it off.. then no restart.
also the security light sometimes flashes sometimes not..
there is a set of relays wired in.. BUT these are going to the door popper.. when i powered them up i could hear the popper click in the door.
im not sure what info.. i will need to post up, so if you have a question, ask and ill answer as fully as possible..
im no stranger to working on cars/trucks... but electrical stuff isnt my forte'.... AT ALL. : )
canter6
Member - Posts: 16
Posted: October 10, 2008 at 10:28 AM / IP Logged
sorry that was supposed to read CANNOT find where the blue and orange wires were cut from
canter6
Member - Posts: 16
Posted: October 10, 2008 at 10:32 AM / IP Logged
btw what is note *1 (im referring to the location of wires sheet you posted) or where can i find this note.
ckeeler
Gold - Posts: 1,461
Posted: October 10, 2008 at 10:58 AM / IP Logged
NOTE *1 THE BCM (BODY CONTROL MODULE) IS LOCATED TO THE RIGHT OF THE GAS PEDAL BELOW THE RADIO.THE PLUGS ON THE BCM FACE TOWARDS THE DRIVERS SIDE.
NOTE *2 USE TAN (-) FOR THE DRIVERS DOOR LOCATED IN PIN B4 OF THE PURPLE PLUG.USE ORANGE (-) FOR THE PASSENGER DOOR LOCATED IN PIN B2 OF THE PURPLE PLUG,MUST DIODE ISOLATE THE WIRES.
NOTE *3 THE PCM (POWERTRAIN CONTROL MODULE) IS LOCATED ON THE PASSENGER FENDER.ON THE 2.2 LITER THE WIRE IS IN A BLACK 80 PIN PLUG PIN 10,AND ON THE 4.3 LITER THE WIRE IS IN A RED 32 PIN PLUG PIN 20.
NOTE *4 IMPORTANT!!!!! THIS WIRE MUST BE CONNECTED AS IGNITION #2 FOR REMOTE STARTING!!!!!
SORRY, i dont know why i forgot to include that
canter6
Member - Posts: 16
Posted: October 10, 2008 at 11:08 AM / IP Logged
thank you.
i was hoping there would be something in that note that could pull my head outta my rear.. and give me a new avenue to go down..
Page of 3
