second amp
benzo33
Copper - Posts: 87
Posted: October 23, 2008 at 11:37 PM / IP Logged
You would need at least the current draw from both amps, 120 amps. Just run 4 to 8 gauge.
2001 Corolla S and 2005 Neon SRT 4 ACR.
04nata
Copper - Posts: 358
Posted: November 04, 2008 at 2:44 PM / IP Logged
I have to find an amp to replace my PTLE (of crap). I want a 4 channel that will give good sound and low draw for at least 50x4 rms, I am looking at this
Blaupunkt THA-475 PnP 4/3/2 Channel 720W Amplifier
but I only have about 150-200 to spend, please give input
04nata
Copper - Posts: 358
Posted: November 04, 2008 at 4:22 PM / IP Logged
looks like I will be going with the TMA T320.4 brand new for $125 which includes a 4 gauge wiring kit also,,,,not a bad deal...
04nata
Copper - Posts: 358
Posted: November 11, 2008 at 2:47 PM / IP Logged
OK here is what I got
4 gauge running from the battery to the trunk with an 80amp circut breaker
to a stinger dist block (3way)
4 gauge power and ground running to the TMA-T500.1 at 2 ohm 500watts (no fuse, only 4 inches long)
8 gauge power and ground running to the TMA-T320.4 60x4 watts running 4 channels at 4 ohm
does this sound like it will be OK? the only reason I went with the 8 gauge is that I ran out of 4 gauge and connectors, figured 8 would be ok for that amp.
my alternator is only 95amp, so I am guessing that until I get a bigger alternator then I will not be able to run the music load with the headlights on,,,,,,,,correct? I do not know what the current draw is for both amps, if you add up all the fuses on the amps it is 120, I now assume that will blow the 80amp circut breaker?
Finally,,,,,,,,,,,,,,where should I go to get the BIG 3 upgraded if I do not feel comfortable doing it myself?   but if I do it myself, do I just use the same type of wire that I used to wire back to the amps,,,,(Stinger,4 gauge) and then use the loom tubing to protect it from heat?
04nata
Copper - Posts: 358
Posted: November 11, 2008 at 8:46 PM / IP Logged
anybody?
boogeyman
Silver - Posts: 359
Posted: November 12, 2008 at 8:00 AM / IP Logged
  I would use 4 AWG at least for the big three .If you dont feel comfortable doing the big 3 yourself take it to a reputable audio shop and they can do it....
04nata
Copper - Posts: 358
Posted: November 12, 2008 at 9:47 AM / IP Logged
04nata
Copper - Posts: 358
Posted: November 16, 2008 at 8:43 PM / IP Logged
thanx so much for answering my questions..........second amp - Page 3 -- posted image.
anyway, I have achieved sound uphoria............
here is my set up and it sounds twice as good as it did, btw I bought the "Little Mermaid" CD to test it with and it is simply amazing
Stinger 4ga from battery back to dist block
Stinger 4g to bass amp
Sting 8ga to mids amp
HU:  PYLE PLD51MUBT
Mids/Highs:
TMA 6.5 in. / 160 mm Component Systems: Injection molded, anodized polypropylene woofer with butyl rubber surround. 1.0 in. / 25 mm ferrofluid cooled, silk-dome tweeter with neodymium magnet. Tweeters are custome mounted INSIDE the vents....Outboard crossover network.
2 each Pioneer 5 way 6x9's in rear deck
All Ran by:
TMA T260.4  60W x 4 @ 4 ohm
Bass:
2each 12" Extreme series by Directed Audio 4ohm ran in parralel to 2ohm
Ran by:  TMA  T2-500.1-------- 500W x 1 @ 2 ohm
Custom ported box rear facing in the trunk.
Tuned and set
sounds amazing
Page of 3
