Wiring Confusion Viper 5901
dwnell35
Member - Posts: 10
Posted: January 15, 2010 at 2:53 PM / IP Logged
i have  done a 07 armada and iam sure they are a lil similar with the door locks. when hookin the door lock/unlock the first pulse unlock the driver and second pulse unlock the rest of the doors. all u need to do is program the r/s system to unlock with a second pulse. or it may have passenger unlock wire from ur r/s system. and on most nissan there are two starter wires and the second one has to be hooked up via relay, which is easier, for cold starts.
dnell
t&t tech
Platinum - Posts: 2,622
Posted: January 15, 2010 at 3:41 PM / IP Logged
You can use a relay or you can use the second igniton wire(pink/white), and program it as second starter!
Posted: January 16, 2010 at 4:12 AM / IP Logged
2 points here.
a) Why do you want to power up the radio during remote start? You're not in the vehicle! Simply set it as a second starter.
b) Unless you're completely paranoid about someone jumping into the vehicle as you unlock it, simply set the unit for double pulse unlock. I've NEVER been asked to do progressive unlocks, except on Ford Transit connects and Mercedes Sprinters, which are set up for it with regards to the load area not the passenger doors.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
