07 silverado 3500 crew cab, viper 5901
ericdrob67
Member - Posts: 8
Posted: January 04, 2009 at 11:44 AM / IP Logged
Hi folks Im having some problems finding a module for my truck. It is a Classic bodystyle(same as 06). Ive already got my Viper 5901 wired in with exception wires i need a module for(door lock/unlock and imobilizer) Most info ive found says to use Directed 457GW... little bit of searching shows the 457GW to have been replaced by 1700G and then 1700G1.
My big questions are: where can i find a module that will work for my truck(all sites ive found the 457GW,1700G and 1700G1 are out of stock).
Ive found plenty of Directed 1900G at a good price... what are the differences between 1700G and 1900G? will the 1900G work with my truck?
Any help is greatly appreciated.
Eric
robertsc
Copper - Posts: 337
Posted: January 04, 2009 at 12:05 PM / IP Logged
i would use pkugm2x
ericdrob67
Member - Posts: 8
Posted: January 04, 2009 at 12:16 PM / IP Logged
I see the pkugm2x is for hybrid/passkey III.... 07 was the first year for the New body style trucks...Mine is a Classic body = same as 06... Do the 06 trucks have Passkey II or III?
thanks
Eric
mricicle
Posted: January 04, 2009 at 12:26 PM / IP Logged
take a look at your key. if it says pk3 you have passkey 3... if it has a plus sign with a circle around it you have passkey plus... if there isnt anything written on the key  you most likely have passkey 2...
Platinum - Posts: 12,488
Posted: January 04, 2009 at 12:28 PM / IP Logged
the iDatalink ADS-DLSL-GM1 will do everything including giving you tach, door trigger, arm/disarm,lock/unlock, defrost and also heated seat activation through temperature. It''s the one that we use all the time and have been 100 % effective on that truck
another-kelly
Silver - Posts: 618
Posted: January 04, 2009 at 12:37 PM / IP Logged
or the latest DEI piece equivalent to 1700G is the XK01. can be bought at bypasskit.com
ericdrob67
Member - Posts: 8
Posted: January 04, 2009 at 12:52 PM / IP Logged
thanks for the input guys, I just ordered the Idatalink ADS-DLSL-GM which combines all three versions(GM1, GM2 and GM3) so i should be covered whether i have PassKey II or III... nothing special about my key, so it appears i have PassKey II.
thanks again
Eric
ericdrob67
Member - Posts: 8
Posted: January 13, 2009 at 12:18 PM / IP Logged
Hi again guys... Im having some problems getting everything working properly.
Prior to Idatalink, truck would remote start for 2-3 seconds, then the theftlock light on dash would start blinking and kill the truck.
During Idatalink install, i thaught i had "type 1" instal as described in the manual... but remote start would run for 2-3 sec then theftlock blinking again and kill the truck.
So, thinking perhaps i had type 2 instal, since anti theft appeared to be killing the truck.... i tried the "type 2" install... now the trucks anti theft light is on steady.
The truck still starts normal with key... but remote start gets about 1/2 a second of crank then nothing.
Any ideas on my two problems?
thanks, eric
ericdrob67
Member - Posts: 8
Posted: January 14, 2009 at 4:24 PM / IP Logged
anyone?
jrod83
Copper - Posts: 81
Posted: January 15, 2009 at 12:55 AM / IP Logged
ericdrob67 wrote:
anyone?
ive always used the 1701g then wire in some resistors on the ignition wires and such and it works fine....ill post up a diagram tomorrow on how to do it....
MECP Certified
I am the loudest and proudest member of the Fighting Aggies Class of '11 WHOOP!
SAW 'EM OFF!
