2006 ford fusion headlamps on
alias20874
Member - Posts: 7
Posted: February 25, 2009 at 5:33 PM / IP Logged
had remote start installed and now my headlights dont cutt off even when i get out with the switch on off there on and the chime is chimming wondering could there be a relay that need replacing
chadwa2003
Copper - Posts: 353
Posted: February 25, 2009 at 5:40 PM / IP Logged
Take it back to the installer and confirm that they correctly hooked the parking light circuit as this vehicle requires a specific relay set up if they used a negative trigger. Eithier way it should go back to the installer to verify this.
If you did it yourself how did you hook up your parking lights, positive or negative?
Platinum - Posts: 13,725
Posted: February 25, 2009 at 9:13 PM / IP Logged
Take the headlight switch apart and look for a burnt trace of foil somewhere.
alias20874
Member - Posts: 7
Posted: February 26, 2009 at 12:27 PM / IP Logged
i been taking it back twice today i went and told him gave me money back but i am pretty hands on so is there a relay that i need to replacer are am i just done for
KarTuneMan
Platinum - Posts: 7,056
Posted: February 26, 2009 at 1:29 PM / IP Logged
Idiot has given this advice before.... and was right on the money!
I say do as he suggested.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 26, 2009 at 3:58 PM / IP Logged
So, you took it back twice today and he still didn't fix it? Did you bring the car back there with an appointment, or just show up at random?
Either way, they're the ones who should be fixing it for you.
However, if you want to use the search feaure here, search for "ford headlight switch." Many of us have burned out these switches, and one installer has told of a procedure to fix it.....although a new one is only around 30 dollars.
alias20874
Member - Posts: 7
Posted: February 26, 2009 at 9:07 PM / IP Logged
ya i had appointments both times i drove 1hr out my way to this place never againdude is a a.s both times I seen people coming in with problems with there stuff he installed and he tells them its not what he did. but ne ways ok even when i unplug the switch there still on will do some more research
Posted: February 26, 2009 at 9:40 PM / IP Logged
That sounds like a plan.  Research is always good.  I wish I knew something that would help you.  It's probably a bad relay.  I would check them all.
alias20874
Member - Posts: 7
Posted: February 27, 2009 at 1:01 AM / IP Logged
how do ui tell if a relay is bad
Posted: February 27, 2009 at 5:28 AM / IP Logged
you need a meter or a relay tester. Harbor Freight sells them. They are on the aisle between the Pipe Stretchers and the Skyhooks.
Edit: They do not sell relay testers at harbor freight. Don't waste your time looking for one. But you might benefit from re-reading this entire thread. There MAY be a bit of helpful information that you have overlooked.
