wireing diagram for pt cruser
drinkenbuddie
Member - Posts: 8
Posted: June 04, 2002 at 11:11 PM / IP Logged
Hey I have an alarm and want to put it in a pt crusier and I looked just like I did for my truck and you guys had it for my truck but no go for newer cars What's up. So it's a band new one 2002 pt crusier.
Please help!!!!!!!
Platinum - Posts: 12,488
Posted: June 04, 2002 at 11:23 PM / IP Logged
Chrysler
PT Cruiser
2001-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
BLUE
Ignition #2:
BLACK/ ORANGE (HEAT/AC)
IGNITION SWTICH HARNESS
Ignition  #3:
N/A
Accessory:
BLACK/ WHITE (RADIO)
IGNIITON SWITCH HARNESS
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
DK. BLUE/TAN
AT COILS
Parking Lights:
BLACK / YELLOW (+)
AT LIGHT SWITCH
Headlights:
VIOLET/WHITE (+)
AT LIGHT SWITCH
OEM Alarm  Disarm:
DK. GREEN
IN DRIVER'S DOOR ****
OEM Alarm  Arm:
DK. GREEN
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 * This Vehicle Is Equipped Wiith Chrysler's Smart Key Engine Immobilizer.
Chrysler
PT Cruiser
2001-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
BLUE
Dome  Lights/Superv:
TAN (DRIVER'S)
DK. BLUE/ORANGE (ALL OTHERS) **
OEM Horn:
RED / BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ DK. GREEN
UPPER KICK PANEL ***
Power  Unlock:
WHITE/ DK. GREEN
Trunk  Release:
N/A
FOLLOWS DOOR LOCKS
Alarm  Input Wire:
TAN (DRIVER'S)
Notes:
Of The Doors. A Negaive Pulse Through A 2.7 K-Ohm Resistor Will Arm The Factory Alarm
drinkenbuddie
Member - Posts: 8
Posted: June 06, 2002 at 2:44 AM / IP Logged
Hey there buddie thanks I sure like that and hope I can do something for you some day. I gots to go install me an alarm!!!!!!!
Posted: June 06, 2002 at 8:24 AM / IP Logged
Good luck and Here's a little more info for the 2002 PT Cruiser:
  • HATCH trigger : TAN/BLACK ( driver's kick )
  • Driver side door trigger : TAN
  • All other door trigger : BLUE/ORANGE ( Passenger kick panel )
Q2Installs
Member - Posts: 16
Posted: June 13, 2002 at 11:27 PM / IP Logged
Thanks for your help guys....That is a big help....Why don't you guys list resistor levels though in your tech notes?  Just curious
Thanks again......
Q
Posted: June 14, 2002 at 5:20 AM / IP Logged
You mean like this : https://www.the12volt.com/resistors/resistors.asp
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
