f 350 diesel severe interference
nfrank89
Copper - Posts: 86
Posted: June 14, 2009 at 4:57 PM / IP Logged
The vehicle:
2001 Ford F-350 Super Duty Diesel 7.2ltr
The System:
Pioneer AVIC-f700BT
Rockford fosgate amps, 2ch and a 4ch and a .5f cap
The problem:
this problem started when i was installing an starter kill switch using the wires at the ignition harness. i was testing the switch so i was cycling the ignition. i turned the truck off then to run and had a significant amount of interference that hadnt been there just a few moments ago.
here's what ive done so far to narrow down the problem:
regrounded the head unit
checked amp grounds. good
ran rca directly to the amp, still buzzed.
there is absolutely no interference in ACC, only in RUN
i pulled the radio fuse and the buzzing still existed
so i started pulling fuses until the buzzing sound went away and i found that the circuit causing the interference is 30amp fuse that controls the fuel heater, wastegate solenoid, and the injector driver module relay. This is all diesil only equipment.
i pulled out the injector driver relay and that eliminated half of the interference but not all of it. i dont know what the wastegate is and the fuel heater im assuming isnt active because it's a warm day. also, when the 30 amp fuse is pulled the wait to start light doesn't come on. the sound doesn't seem to be following anything as far as i can see. when the truck is running turning on the AC or anything else that draws a lot of power changes the tone of the interference.
so this is where i'm at now, i tried disconnecting the kill switch and checked all the wiring and its fine so i know its not the kill switch. i dont know what to do next... any help at all would be greatly appreciated, i think my client is scared i really messed something up do i want to get it fixed asap!
tommy...
Gold - Posts: 1,901
Posted: June 14, 2009 at 5:03 PM / IP Logged
So it does this with the truck off...But in run position...? Or only w/ truck running?
M.E.C.P & First-Class
Platinum - Posts: 13,726
Posted: June 14, 2009 at 5:07 PM / IP Logged
nfrank89
Copper - Posts: 86
Posted: June 14, 2009 at 7:37 PM / IP Logged
Okay heres what it sounds like, in the video it's a lot louder than it actually is.
annoying interference
nfrank89
Copper - Posts: 86
Posted: June 14, 2009 at 7:39 PM / IP Logged
in acc mode: no interference
off position : no interference
in run w/truck running or not running: it makes the buzzing sound
Posted: June 14, 2009 at 7:44 PM / IP Logged
Hey everybody, it happened again.  I wish I knew what was causing it.  It must be IE8's invisibility function.  Does anyone know how to defeat it?
nfrank89
Copper - Posts: 86
Posted: June 14, 2009 at 7:57 PM / IP Logged
are you saying this is a common problem?
Posted: June 14, 2009 at 8:29 PM / IP Logged
I plead the 5th.   You will have to make that call.  Following are the search results for pioneer noise  there are 361 topics that meet  that criteria.
https://www.the12volt.com/installbay/search.asp?KW=pioneer+noise&SM=1&SI=PT&FM=0&aid=199561&OB=1
nfrank89
Copper - Posts: 86
Posted: June 14, 2009 at 8:53 PM / IP Logged
i dont think it's the head unit because it still makes the noise even when the radio fuse is not installed in the fuse box
Posted: June 14, 2009 at 9:11 PM / IP Logged
Well let us know what it is when you figure it out.
Page of 4
