ford ranger 2002
mrskater5000
Member - Posts: 7
Posted: June 18, 2009 at 10:37 PM / IP Logged
I'm wiring my car alarm and my truck has positive door triggers and my alarm only has negative trigger inputs... What do I do about this?
Platinum - Posts: 13,726
Posted: June 19, 2009 at 1:41 AM / IP Logged
Your alarm has a wire for positive door trigger. Tell us what kind of alarm you have and we can probably tell you what color the wire is.
mrskater5000
Member - Posts: 7
Posted: June 19, 2009 at 4:29 AM / IP Logged
I have a crime guard 350i5
Posted: June 19, 2009 at 6:03 AM / IP Logged
If brown is siren, and green is negative door input, and blue is negative input for sensors,  Violet should be positive door trigger.
mrskater5000
Member - Posts: 7
Posted: June 20, 2009 at 12:09 AM / IP Logged
Still no luck :( I tried hooking it up to the dome light and the door triggers from the door itself am I doing it right?
Posted: June 20, 2009 at 3:46 AM / IP Logged
Which wire of your alarm do you have connected to the Siren? What color?
I am not so sure that your vehicle has positive door triggers.  Can somebody confirm?
mikvot
Gold - Posts: 1,043
Posted: June 20, 2009 at 10:05 AM / IP Logged
Nope, it does not. It will have negative door triggers. Yellow/black for drivers door, and gray/red for passengers door.
mrskater5000
Member - Posts: 7
Posted: June 23, 2009 at 10:56 AM / IP Logged
I have the brown wire connected to the siren is this the wrong wire?
Posted: June 23, 2009 at 11:13 AM / IP Logged
Is the siren working?
mrskater5000
Member - Posts: 7
Posted: June 23, 2009 at 5:15 PM / IP Logged
Yeah and whenever I hook the door triggers up to the blue wire (with a diode) it goes off when I have the door closed and goes silent when I have the door open
