02 impala radio and headlights
jla74
Member - Posts: 21
Posted: October 18, 2009 at 12:36 AM / IP Logged
Installed a python 1400xp today and here is what i have for issues, hoping maybe someone can help.
When using the r/s the radio reads "LOC"
Headlights don't come on automatically like they did prior to the install.
If I start the car with the key everything works like normal.  If you have any suggestions I would appreciate it.  Thanks.
chriswallace187
Gold - Posts: 1,661
Posted: October 18, 2009 at 4:58 AM / IP Logged
That sounds unusual - the only thing I can think of would be if you weren't powering both the orange and the brown accessory wires with the remote starter? Make sure to power both as Accessory and not Ignition also.
C Renner's Auto Electronix
Posted: October 18, 2009 at 6:54 AM / IP Logged
From where have you taken your main power and grounds for the 1400XP?
tommy...
Gold - Posts: 1,901
Posted: October 18, 2009 at 8:40 AM / IP Logged
BatteryRED(+)IGNITION SWITCH HARNESS
02 impala radio and headlights -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
02 impala radio and headlights -- posted image.Ignition 2DARK.GREEN(+)IGNITION SWITCH HARNESS
02 impala radio and headlights -- posted image.Accessory 1ORANGE(+)IGNITION SWITCH HARNESS
02 impala radio and headlights -- posted image.Accessory 2BROWN
02 impala radio and headlights -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
02 impala radio and headlights -- posted image.Anti-Theft TypeRESISTOR BASED SYS
02 impala radio and headlights -- posted image.Anti-Theft DescriptPASSLOCK II
02 impala radio and headlights -- posted image.Key SenseLIGHT GREEN(-)IGNITION SWITCH HARNESS
02 impala radio and headlights -- posted image.TachometerWHITE(AC)COIL ON TOP OF ENGINE
02 impala radio and headlights -- posted image.Crankshaft SensorLIGHT BLUE/BLACK(-)AT PCM MODULE UNDER AIR CLEANER BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD02 impala radio and headlights -- posted image.
02 impala radio and headlights -- posted image.Camshaft SensorBLACK(-)AT PCM MODULE UNDER AIR CLEANER BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD02 impala radio and headlights -- posted image.
02 impala radio and headlights -- posted image.Speed SenseDARK GREEN(AC)BCM ABOVE BRAKE PEDAL GRAY16 PIN PLUG
02 impala radio and headlights -- posted image.Parking LightsLIGHT BLUE(-)AT HDL SWITCH OR BCM GRAY 16 PIN PLUG
02 impala radio and headlights -- posted image.Brake LightsWHITE(+)SWITCH ABOVE BRAKE PEDAL
02 impala radio and headlights -- posted image.Reverse LightsLIGHT GREEN(+)LIGHT02 impala radio and headlights -- posted image.
02 impala radio and headlights -- posted image.HornBLACK(-)AT COLUMN OR BLACK/ BLUE PLG ABOVE BRAKE
M.E.C.P & First-Class
