5 wire
mdslax
Posted: January 14, 2010 at 8:52 AM / IP Logged
can someone tell me how to relay 5 wire for a trunk release motor...its for a 08 grand prix if that matters...
Platinum - Posts: 13,725
Posted: January 14, 2010 at 11:35 AM / IP Logged
Audiovox does not have it listed as a 5 wire setup.  Where are you getting the 5 wire info from?
Trnk ReleaseLIGHT BLUE(+)AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN
Pin 45.
If you do need a 5 wire, Find the wire that powers the solenoid, cut it and connect the solenoid wire to terminal 30.  Connect the other cut end to terminal 87A.  Connect 87 and 86 to the battery via a 10 amp fuse.  Terminal 85 connects to the output wire of your alarm system.
mdslax
Posted: January 14, 2010 at 11:48 AM / IP Logged
direct techs says its a 5 wire...ill try to relay it as positive and see what happens...thanks for the info
Posted: January 15, 2010 at 2:40 AM / IP Logged
Ever thought of standard procedure, i.e. test what directwire or any one else says before posting the question?
mdslax
Posted: January 18, 2010 at 12:39 PM / IP Logged
you know what else is standard procedure? not being a dbag. i just asked a simple question and i got my answer and even thanked the guy for it, so where you fit in this conversation is beyond me, if your trying to sound smart you just made yourself look like an idiot...go F yourself homo
