astroflex remote starter
wthoracer20
Member - Posts: 8
Posted: January 28, 2010 at 11:07 PM / IP Logged
i have the astrostart 1000 series in a truck i just bought but when i go to start my truck i hit the botton and all th elights go on and the dash lights but then everythnig just shuts back off. and answers to why that does that?
monty_77
Copper - Posts: 491
Posted: January 28, 2010 at 11:16 PM / IP Logged
check the on/off switch on the bottom of the dash make sure its on
wthoracer20
Member - Posts: 8
Posted: January 28, 2010 at 11:19 PM / IP Logged
ya thats on but i have also tryed it while it was off to and it does nothing.
monty_77
Copper - Posts: 491
Posted: January 28, 2010 at 11:23 PM / IP Logged
check the hood pin and make sure it not broken if its broke or not adjusted right, if making contact it will give a signal that the hood is open and will cancel the start to see unplug the wire and try it
the switch has to be on to remote start
also make sure the wires on the back of the switch are not broke
wthoracer20
Member - Posts: 8
Posted: January 28, 2010 at 11:30 PM / IP Logged
well i kno my hood is not adjusted right cuz it takes a few times fro the hood to pop so ill check that ou and see what it does. thanks for all the advise
monty_77
Copper - Posts: 491
Posted: January 29, 2010 at 12:24 AM / IP Logged
think i found the installation manual for this starter if you tell me how many flashes the led one the brain under the dash i might be able to tell you the problem better
that is after a failed start and before the brake is pushed
if the brake is pushed it will clear the codes
wthoracer20
Member - Posts: 8
Posted: January 29, 2010 at 12:46 AM / IP Logged
do you mean when i hit the start button how many times the led light blinks??
monty_77
Copper - Posts: 491
Posted: January 29, 2010 at 12:50 AM / IP Logged
yes after you push the start button and it fails to start count the flashes of the led on the unit under the dash
KarTuneMan
Platinum - Posts: 7,056
Posted: January 29, 2010 at 10:22 AM / IP Logged
You are hoping for 5 flashes (hood pin problem)
The hood pin on these units is magnetic (total crap) You can replace it, but the unit requires some programming changes.
There is NO clearing of codes.... if there is a no start situation, the problem must be fixed before it will start!
wthoracer20
Member - Posts: 8
Posted: January 29, 2010 at 3:25 PM / IP Logged
i hit the start button but then it flashes way to fast for me to count them???
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
