remote start 2008 dodge ram
harleyrob
Member - Posts: 17
Posted: March 01, 2010 at 3:07 PM / IP Logged
I put an Audiovox Pro 9776 in a 2008 Ddge Ram used a DEI CHALL module every thing works fine except initiate remote start the truck runs for 40 seconds and then shuts off,ANY IDEAS,PLEASE HELP!
tedmond
Gold - Posts: 4,610
Posted: March 01, 2010 at 4:37 PM / IP Logged
make sure its bypassed properly by leaving a key in the ignition in the off position.
also make sure you program the tach for the audiovox unit.
Ted
Compustar Expert
Moderator - Posts: 12,488
Posted: March 02, 2010 at 1:07 PM / IP Logged
Are you using W2W or D2d for the bypass ? Also, you didn't mention if the truck was a diesel or gas ?
harleyrob
Member - Posts: 17
Posted: March 02, 2010 at 1:36 PM / IP Logged
using d2d diesel got it working thanks all for the help
bikewiz
Posted: October 10, 2010 at 11:51 PM / IP Logged
What wound up being your problem?  I'm trying to find a solution to the CHALL not cranking my 2006 diesel with a python 991 connected w2w.
Saturday, August 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
