python 991 problems
toffe
Member - Posts: 6
Posted: April 18, 2010 at 4:09 AM / IP Logged
Hello
I've got a brand new Python 991 to install on my VW Passat Estate 91.
First of i wonder; how much do i have to "connect" before i can start the device? I've connected 4 +12 constant wires and tried to start the device but the key would not sync with the device. (I did this for testing purposes, so i can meter out what cables does what to be sure that i connect the correct cable). But the problem as i said; It wont start the "brain" or sync with key. Either will the "control center" start blinking as it should?
Secound: I've tried to connect the "door Lock". The harness looks like this:
python 991 problems -- posted image.
the problem i've encountered is that the door lock/unlock button only have 1 wire. Where 0ohm is lock and 1800ohm is open? What can i do? Just put a 1800ohm resistans on the wire?
Third:
I wonder if my "understanding of this harness" is correct:
H3/1 - Pink - The cable which only shows 12v at ignition position 1, but zero at ignition 2? (My car i think have 3 positions before the "ignition" is on and ready to start car).
H3/2 - RED / white - I've connected this to 12v constant (just connected it to battery)
H3/3 - Orange - Not needed, gives 12v when i press accessory on the key
H3/4 - Violet - The wire which gives 12v when i cranks the motor
H3/5 - Green - The wire which gives 12v+ to the violet when i turn the key
H3/6 - Red - constant 12v (to battery)
H3/7 - Pink/white - Where does this go?
H3/8 - Pink/black - Where does this go?
H3/9 - RED / black - Constant 12v (battery)
toffe
Member - Posts: 6
Posted: April 18, 2010 at 4:15 AM / IP Logged
Sorry its a VW Passat 1999 Estate ! :) not 91
Posted: April 18, 2010 at 7:09 AM / IP Logged
First your door locks. You will need a 451 module or two relays. Your lock output is not strong enough to get past the resistor. Second By-pass? Third have it fitted professionally, don't even attempt it yourself as an example pink goes to the ignition wire (BLACK/ red?) which stays live from ignition through crank, there are many other mistakes in your assumptions.
toffe
Member - Posts: 6
Posted: April 18, 2010 at 12:46 PM / IP Logged
Hehe, i knew i had a lot of wrongs :(
There is no professional dealers in norway for this. Thats why i asks for a "guide" thoughout the connection.
The nearest dealer is in London i think which would be expensive to both travel & install.
And the manuals from Python are ... not expainable :P The manual for the python 990 had more explanation than the 991.
Darn! :( Noone have done this and can explain "all" the wires?
Posted: April 18, 2010 at 1:51 PM / IP Logged
Far too complicated to explain. This is not a DIY alarm. You will eventually be driving to London to have me install it, cheaper than the damage you will otherwise do to your vehicle.
tedmond
Gold - Posts: 4,610
Posted: April 18, 2010 at 5:58 PM / IP Logged
lol i think howie will be saving you from this install.
any DEI unit is not DIY friendly, its for the more technically inclined individuals/installers.
pink/white 87 - second igntion.
pink/black - not needed
Ted
Compustar Expert
toffe
Member - Posts: 6
Posted: April 19, 2010 at 5:37 AM / IP Logged
I see that it's not a DIY. But still i really wanna try! :)
The main problem is that i dont get any "life" into the brain? When i connect only "RED" and "BLACK" the control center should start blinking?
Or what do i miss? Just to see how the control affects the diffrent wires e.t.c. I'm more of a logical person to measure out the values then do a search for where e.t.c?
tedmond
Gold - Posts: 4,610
Posted: April 19, 2010 at 6:43 AM / IP Logged
if you got a battery on a bench start testing.
h1-2 and 3 should be hooked up, wire up door trigger and try to program the remotes.
Ted
Compustar Expert
toffe
Member - Posts: 6
Posted: April 19, 2010 at 8:26 AM / IP Logged
But, should'ent the control center give any sign of life when i connect? I've connected the red and black (+12v and ground). And i inserted the "safety switch" and set it to "on". Theese 4 inputs should be enough to power it on? (I've also connected the door trigger, but not the siren as you said. Should i maby take that too? I thought it should be enough with only 2 wires. +12v and 0v :P
anonymous1
Copper - Posts: 151
Posted: April 19, 2010 at 8:41 AM / IP Logged
tedmond is offering good advice.
By using a test bench (dining table) with a regulated 12v supply, you can do a mock-up and look for life, proceed to programming.
If you still get no signs of life then you know the wiring on your vehicle is not part of the equation.
Do you own a digital VM? Test leads?
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
