autopage car alarm
sapperb
Member - Posts: 8
Posted: July 09, 2010 at 6:55 PM / IP Logged
I don't see a place to do and intro, so i will do it here.  My name is Bruce and i recently retired after 20 years of active duty Army service.  I live in California and i am now a contactor that works for the Department of Defense. My current job is that I am an instructor and i teach our military how to go after the IED (Improvised Explosive Devices (roadside bombs) makers and financers. I was an Explosives Expert in the Army.  Ok here is my problem. About 6 years ago i had an Auto Page car alarm professionally installed in my truck (2000 S10).  It is a base model and did not come with a factory alarm, power windows and locks and keyless entry.  This has happened in the past only once.  I set the alarm before going to bed, wake up the next morning and i have power but it won't start.  Push the little red button under the dash and it would start. That is not the case now.  I push it and it won't start.  i lost the manual years ago.  Can anyone one, point me in the right direction to trouble shoot it.  Thank you so much for any effort on this issue.
sapperb
Member - Posts: 8
Posted: July 09, 2010 at 7:36 PM / IP Logged
I just went on line and i found out that it is a auto page RF-310.  hope tis helps.
Posted: July 10, 2010 at 6:31 AM / IP Logged
SOUNDS like there's a starter cut relay, a connection might have come adrift.
A Bosch pattern 5 pin relay..should be wired thus:-
Armed neg out from alarm (Goes to neg when alarm is activated)85
Ignition plus (live also whilst cranking) 86
Starter, wire starter side to 30
Starter, key side to 87a
Terminal 87 not used unless a Rem/Start is used.
lectricguy
Copper - Posts: 359
Posted: July 10, 2010 at 7:27 AM / IP Logged
I agree with Howie.  Most likely you have a wire which became disconnected in the starter disconnect relay.  This is a fairly straight forward alarm system.  Sounds like the system is working but won't allow you to start the truck.
I added the RF-310 Operations and Install guides to the download section of this site to help you debug this.
AutoPage RF-310 Operations Manual
AutoPage RF-310 Install Guide
Lectric Guy
sapperb
Member - Posts: 8
Posted: July 10, 2010 at 10:42 AM / IP Logged
Thank you so much for the help and replies.  First off i a totally stupid when it comes to electricity and wiring diagramsautopage car alarm -- posted image.. How do i know if i have the 5 pin or 6 pin?  I know you guys can help me fix this but you might have to put it into elementary form and or put a "barney" suit" on for meautopage car alarm -- posted image..  I apologize for the stupidity.
lectricguy
Copper - Posts: 359
Posted: July 10, 2010 at 12:42 PM / IP Logged
Ans: By the wire colors and number of wires.   I would focus on the orange wire in the 6 pin connector.   That should be connected to your starter kill relay.   I would begin by looking for a discoonnected wire on one of the wires going to the relay.
Lectric Guy
Posted: July 10, 2010 at 1:35 PM / IP Logged
There are 2 relays for starter cut shown on the install manual, follow the orange and yellow from the alarm.
Incidentally, there are two diagrammes showing starter - cut relays, the second is correct.
sapperb
Member - Posts: 8
Posted: July 10, 2010 at 10:30 PM / IP Logged
I know that this may be hard for you guys to answer, but how can i identify the relays and the alarm??  The only thing I can ID is the horn.  is there an alarm control module or something under the dash or under the hood?  Again thank you so much for the effort and the replies, you don't know how much i appreciate it.  Like I said, i didn't install it.  I took it to an audio store to have it professionally installed about 6 years ago after my first tour in Iraq and that was in Missouri and i am nowback i cali.  It has to be a loose wire or something.  My S10 is an off road prerunner and i bounce it around the dezert, and yes it has been airborne but it hasn't been over a week since i took it to the dezert..  I have tomorrow off, so I think I will take my dash apart and also check out the wires going to the starter.  Again, thank you.
Posted: July 11, 2010 at 2:27 AM / IP Logged
It will be under the dash, probably driver side, black plastic box about 1 x 3x 5". There are loads of adverts from relay manufacturers in the relay section, or Google Bosch relays.
To be honest from the questions you're asking I would seriously advise taking your vehicle to a pro.
sapperb
Member - Posts: 8
Posted: July 11, 2010 at 10:23 AM / IP Logged
OK thank you so much. I am going to take the dash a part today. I will let you know what i find. I can'tdrive it to a pro and i don't want to pay for towing.  Thank you so much
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
