08 tsx, viper 5901
spudsmac
Member - Posts: 21
Posted: September 06, 2010 at 1:35 PM / IP Logged
I do, but I don't think it's the relay that's not working right since it works fine for remote start. I just don't know where else to troubleshoot. Maybe in the settings?
spudsmac
Member - Posts: 21
Posted: September 06, 2010 at 1:47 PM / IP Logged
Ok. I see what you mean. It sounds like there is only one relay doing anything when I press disarm. How would I hook up an external one?
spudsmac
Member - Posts: 21
Posted: September 06, 2010 at 2:08 PM / IP Logged
I did some tinkering and found out that I can start it with the key if I only push in the left side of the H3 plug, but when I plug in the whole plug, it won't start with the key 08 tsx, viper 5901 - Page 2 -- posted image.
spudsmac
Member - Posts: 21
Posted: September 06, 2010 at 2:20 PM / IP Logged
Can I just solder a wire in the brain and just bypass the starter kill? I don't really care about that feature. I'm not worried about someone stealing my car, at least not by starting it.
awdeclipse
Copper - Posts: 285
Posted: September 06, 2010 at 2:33 PM / IP Logged
You mentioned the starter doesn't disengage? And you also have trouble with the starter kill? Have you double checked the connections for starter and ignition?
spudsmac
Member - Posts: 21
Posted: September 06, 2010 at 3:09 PM / IP Logged
Yes I did check it. I went by http://tl.acurazine.com/forums/showthread.php?t=706816 since the install was very similar. The starter wire on the TSX is BLACK/ white though unlike the TL.
Another thing, on the wiring diagram https://www.the12volt.com/installbay/forum_posts.asp~TID~99069 it says that the parking light wire in the steering column is neg. I tested it and it shows 12v when off and 0 when on when I test using +12v. Is this right? Wouldn't it read 0 when off, then 12 when on?
Platinum - Posts: 7,828
Posted: September 06, 2010 at 3:41 PM / IP Logged
For the parking light wire, how are you testing it?  Connect the DMM red lead to constant +12v and connect the black lead to the (-) Parking Light wire.  The DMM should be set to 20v DC ( unless it is auto-ranging ) and will show +12 volts when the parking lights are turned on.
spudsmac
Member - Posts: 21
Posted: September 06, 2010 at 4:42 PM / IP Logged
It's the opposite 08 tsx, viper 5901 - Page 2 -- posted image.
I set it up just like that, but when the lights are off, it reads 12v and when lights are on, 0v.
spudsmac
Member - Posts: 21
Posted: September 06, 2010 at 4:43 PM / IP Logged
Also, the starter kill just started working right out of the blue. IDK why it was acting up before, but at least I know how to start it if it messes up again.
Platinum - Posts: 12,488
Posted: September 06, 2010 at 6:54 PM / IP Logged
The proper (-) parking light wire will read 12 volts (+) at rest and will go to ground when turned on. the reading on the voltage will vary from 12 volts down to 5 volts depending on the vehicles circuitry.
Page of 3
