viper 5902 in audi a6
fukinavit
Member - Posts: 6
Posted: September 20, 2010 at 1:34 AM / IP Logged
Hi all,
i am currently researching to install the viper 5902 in my 2000 audi a6 with manual transmission. So far i have figured out most of the wires but i have a few questions left that if anyone could answer that would be fantastic. just to say i have installed 3 remote starts before, all just basic start/stoppers and all with automatic transmissions. So this install is a bit more complex both as in the car, the RS and with the manual transmission.
im going to use the starter kill so i will just cut the starter wire and solder the violet and green wires to the correct ends, however in the wiring diagram for my car it says i have a starter 2 wire (blue), there is no blue wire in the main harness next to the main starter wire (RED / black). there is however a blue wire of thin gauge in the harness next to it, is this my 2nd starter wire? its of thin gauge so i dont understand its purpose. The install note says these 2 wires must be connected together to the rs starter wire to help in cold weather? Can i test this blue wire, if so how?
i think i have figured out the lights as this rs can isolate the circuit (parking lights, white to lights, white brown to switch. i will connect the dark blue h2/10 wire to the clutch switch and the neutral wire to the hand brake wire. However on my wiring diagram i cannot find the colour or location of this hand brake wire so if anyone has this info and also the rear defogger wire that would be great.
sorry for the story, but i hope someone can understand what i mean.
Posted: September 20, 2010 at 3:02 AM / IP Logged
I've never known them to have a second starter wire in Europe, test the blue wire on crank with a DMM.
Don't join, cut the red black and use the flex relay as second starter output if needed.
There are two ignitions though.
The best way to by-pass this car's immobiliser is to use a 556U with a black valet key available, programmed from a dealer, the 556 wired to European vehicle spec., i.e. no loop.
You might have nightmares picking up the locks, normal i.e. in the driver's kick well is OK but this doesn't give you deadlock or window close depending on year, find the lock wire, neg pulse, extend the pulse to see if it closes the windows, it depends on the year.
All door contacts can be picked up at the body/factory alarm module either under carpet in front of driver's seat or right hand rear in trunk area.
Definitely a non-DIY job.
Posted: September 20, 2010 at 3:38 AM / IP Logged
Parking brake, BROWN / black, the blue is the alternator lead, irrelevant.
Find parking brake at rear of instrument panel which is the easiest place to pick up the ignition feeds and run cabling across.
WARNING If you remove any components, do not turn on the ignition, you've been warned.
You will find lots of conflicting info, this is because according to my wiring source, some electrical systems were changed 4 times from 95 to 02!
fukinavit
Member - Posts: 6
Posted: September 20, 2010 at 7:01 PM / IP Logged
thanks for the advice and help howie.
on my model i do not have an immobiliser,  it was just before the cut off date for this i believe, so that parts easy. thanks for the blue wire heads up, ill leave that alone then and just connect the 1 starter wire through the starter kill. Not sure what you mean if i remove a component and then turn on the ignition?
tedmond
Gold - Posts: 4,610
Posted: September 20, 2010 at 8:29 PM / IP Logged
+1
if anything is disconnected, do not power up ignition, the system will do a self diagnostics, notice devices are not connected and check lights are going to pop up everywehre.
with that being said, most of the stuff can be grabbed under the seat at the secu (i beleive tahts what they call it) but its very tight. you should run wires and have the brain in the dash area. I attempted an a4, and howie gave me some pointers, but it was def not a diy car. it gave me trouble as well.
Ted
Compustar Expert
Posted: September 21, 2010 at 3:46 AM / IP Logged
No transponder? European market Audis had them from about 93, it's highly unlikely unless you've already tried a hot wire with the key removed about 10ft. from the vehicle.
tedmond
Gold - Posts: 4,610
Posted: September 21, 2010 at 6:30 PM / IP Logged
2000 audi a6 with no transponder?
i as well highly doubt it.
Ted
Compustar Expert
fukinavit
Member - Posts: 6
Posted: September 21, 2010 at 7:41 PM / IP Logged
yep, my 2000 audi according to my owners manual, bently manual and online research, my car does not have an immobiliser. over here in canada and the u.s we are well behind europe as like you say had immobilisers in the early 90's. if you still dont believe me check out the link below.
www.ross-tech.com/vag-com/cars/immobilizer.html
so far all is going ok, still gotta find that park brake wire, there is like a billion of them in there.
Posted: September 22, 2010 at 2:18 AM / IP Logged
That link says North American cars from 2000, check as I described above ref. hot wiring and let us know.
Posted: September 22, 2010 at 2:19 AM / IP Logged
Also as I've already told you parking brake wire is BROWN / black to instrument panel.
