wiring, infiniti g35 2008 remote starter
borderline
Posted: October 03, 2010 at 9:32 AM / IP Logged
I'm new here and what a nice find! Hello to the 12volt communitywiring, infiniti g35 2008 remote starter -- posted image.
I have yet to find this for my G35 2008 sedan (V36 engine)
I need wiring infos to install a remote starter add on (OMEGA excalibur RS120DP) Will also use the DEI XK09 for my immobilizer bypass.
Any help is highly appreciated!
Mike M2
Platinum - Posts: 2,652
Posted: October 03, 2010 at 10:08 AM / IP Logged
http://techservices.audiovox.com/
Go here and sign up for free tech info....
Mike M2
Tech Manager
CS Dealer Services
dasbogie
Silver - Posts: 514
Posted: October 03, 2010 at 10:14 AM / IP Logged
Also, go to xpresskit.com and punch in your vehicle info in the top right.  When the modules load scroll down to XK09, click on the install guide and that will give you what you need.
Advanced
borderline
Posted: October 03, 2010 at 1:31 PM / IP Logged
Great thanks! I knew the xpresskit website but not audiovox.
Even after reading, I am unsure about one thing: the trigger start for my add on remote starter. The manufacturer suggest to use the UNLOCK button to activate the remote starter (because it also disarm alarm system) Great idea, but my car use the same wire to disarm alarm and unlock doors (PIN 34).
So, Should I tap that wire into one INPUT (remote start activation) and one OUTPUT (OEM alarm disarm) of my remote starter?
I only have basic knowledge in electronics and I am unsure of this, just wan to make sure this won't blow something inside the remote! Any idea?
Thanks everyone
See pic here:
Platinum - Posts: 7,827
Posted: October 03, 2010 at 4:19 PM / IP Logged
If you are using the factory FOB to unlock the car, that will turn off the alarm & unlock the doors and I guess the unlock pulses will trigger the remote starter.  There would be no need to connect the remote starters Alarm DisArm wire ( its already disarmed and unlocked ).  But now your car is unlocked...
 I can't see the polarity of the Remote Start Activation Input Trigger, not sure if its a (+) or a (-).
The standard way is to use the Lock Motor wire to trigger the remote starter.  You would press the Factory FOBs lock button twice or three times to trigger a remote start.  The remote start would output a disarm to the cars' factory alarm system thru that Light GREEN/ Black wire and then start the car.  The alarm is off but the car is still locked.
Posted: October 03, 2010 at 5:53 PM / IP Logged
Another interesting point.  I haven't done an Infinity G35 remote start but some Japanese cars ( Honda and Toyota ) disable the factory FOB if the engine is running.  ( If you install a system like yours on a 2007 Honda CR-v, after you start it, you can't use the factory remotes to unlock the doors.  Have to use a key. )
I would give your car a test.  Start it with the key and while it is running try to lock or unlock it with the factory FOB.
Mike M2
Posted: October 03, 2010 at 7:06 PM / IP Logged
ALL Nissan products still allow the remotes to work even with the motor running. They even disarm the factory alarm.
Mike M2
Tech Manager
CS Dealer Services
borderline
Posted: October 04, 2010 at 12:20 AM / IP Logged
The Remote Start Activation Input Trigger is a (-)  And YES  I can use the FOB while the car is running.
What a great help, thanks guys!
Now all I need to figure is what wire to use to disarm the alarm without having to unlock doors...My only clue for now :)
Posted: October 04, 2010 at 6:54 AM / IP Logged
This info from AudioVox.
Alarm Disarm     YELLOW  (-)     MASTER WINDOW CONTROL SWITCH
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, WILL ALSO UNLOCK ALL DOORS WITH A DOUBLE PULSE
This info from Bulldog Security.
 POWER UNLOCK     NOTE #4       @ POWER WINDOW Main Switch, (WHITE, 16-PIN PLUG), PIN 6 or 7
NOTE #4: TEST this wire while Turning the KEY in the Drivers Door. This wire will also DISARM the
FACTORY ALARM. The UNLOCK wire is a YELLOW (-), TYPE B, (Sedan), WHITE (-)
(Coupe and Convertible) Requires Double Pulse.
It appears using the UnLock wire but giving only a single pulse might disarm the factory alarm system but not unlock the doors.  Perhaps one of the Nissan / Infinity experts can jump in here.
On some remote start units, they can be set to "Unlock before start and lock after start" or just "lock after start".  I didn't notice any door lock or unlock outputs from your unit, though.  Can the disarm output be set to "double pulse"?  Here is a link to the install guide of the "add on" remote start unit I use :  http://www.ultrastarters.com/Feature_Sheets/U1155/MAN-1155TL-INSTALL-U.pdf   It will give you an idea of another units programming options and capabilities.
beegbie
Copper - Posts: 341
Posted: October 04, 2010 at 7:36 AM / IP Logged
The factory alarm will not have to be disarmed for remote start. So all borderline needs to do now is trigger his remote start. The factory alarm disarm and unlock wires listed above will not pulse when using the factory remote to unlock the doors. He will need to use a relay and turn the lock actuator +signal into a -signal to turn on the remote start. Set the remote start to 2 or 3 pulse start and just hit lock 2 or 3 times to remote start.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
