1987 ford mustang keyless entry
speedy911
Posted: January 17, 2011 at 12:04 AM / IP Logged
I was looking at 12volt.com and it says
Door Lock - Pink/Light Green - Drivers Kick Panel
Door Unlock - Pink / YELLOW - Reverse Polarity
What exactly do I connect to what?
Here is the wiring diagram for the unit.
How do I wire the 5-Wire connector?
1987 ford mustang keyless entry -- posted image.
Thank you all in advance.
Posted: January 17, 2011 at 3:03 AM / IP Logged
It depends on what you are doing.
Let us know what you are installing and how many lock wires it has, either 2 or 6.
Posted: January 17, 2011 at 3:07 AM / IP Logged
On further examination, it probably means pink / YELLOW, neg. pulse to lock, pink/green, neg. pulse to unlock.
Posted: January 17, 2011 at 3:26 AM / IP Logged
Sorry, forget my second post, go by the first post.
the12volt
Administrator - Posts: 3,959
Posted: January 17, 2011 at 3:27 AM / IP Logged
Howie, they are reverse polarity. Both leads rest at ground through the switch.
speedy911, Cut the Pink/Light Green lock wire. The switch side will be connected to the PK/YL lead of the 5 pin harness of the keyless entry. The motor side will be connected to the YEL lead of the 5 pin harness of the keyless entry.
Cut the Pink / YELLOW unlock wire. The switch side will be connected to the PK/GR lead of the 5 pin harness of the keyless entry. The motor side will be connected to the LT.GR lead of the 5 pin harness of the keyless entry.
The PK lead of the keyless entry will be connected to a fused constant 12V+ source.
1987 ford mustang keyless entry -- posted image. the12volt • Support the12volt.com
Posted: January 17, 2011 at 3:41 AM / IP Logged
Yes, I realised this AFTER I checked, problem is what's our friend trying to do, over here I've never even SEEN an 87 Mustang!
Sorry, just remembered did one about 10 years ago, 5 wire.
To our first poster 5 wire simply means you are interrupting the wiring pathway of the lock and unlock MOTOR wires via 2 relays, that's why I asked what you were trying to do and how many lock wires were on the unit,if 2 you will need the relays and the diagramme as shown in the relay section, if 6 you won't.
12 volts, go to bed!
speedy911
Posted: January 17, 2011 at 3:53 AM / IP Logged
Thank you very much for the clarification. I will report back tomorrow with the results.
the12volt
Posted: January 17, 2011 at 3:57 AM / IP Logged
Howie, his unit has built in relays (see "5-wire connector" in image)... maybe you should go back to bed :p
Posted: January 17, 2011 at 4:09 AM / IP Logged
You're right, I didn't know if that photo was an OEM Ford part, I assumed the poster wanted to ADD a keyless entry. The bed comment was that it must be about 4:00am in your part of the world. Since you aren't Craig M. I can't add any "swamp person" comments either.
