problems, dball, 09 accord
syl20rochon
Copper - Posts: 298
Posted: April 17, 2011 at 12:41 PM / IP Logged
I'm putting stars to required wires...
Primary harness (H1), 12-pin connector
H1/1 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT
H1/2 RED (+)12v CONSTANT INPUT*****
H1/3 BROWN (+) SIREN OUTPUT****(If you install the siren or you can use the horn output (BROWN / white (-)))
H1/4 WHITE/ BROWN LIGHT FLASH ISOLATION WIRE - PIN 87a of onboard relay
H1/5 BLACK (-) CHASSIS GROUND****
H1/6 VIOLET (+) DOOR TRIGGER INPUT
H1/7 BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT
H1/8 GREEN (-) DOOR TRIGGER INPUT
H1/9 BLACK/ WHITE (-) 200mA DOME LIGHT OUTPUT
H1/10 WHITE/ BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION INPUT
H1/11 WHITE PARKING LIGHT OUTPUT*****
H1/12 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT
Auxiliary harness (H2), 8-pin connector
H2/1 LIGHT GREEN/ BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT
H2/2 LIGHT GREEN / WHITE (-) 200mA FACTORY ALARM ARM OUTPUT
H2/3 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT
H2/4 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT
H2/5 WHITE/ BLACK (-) 200mA AUX 3 OUTPUT
H2/6 LIGHT BLUE (-) 200mA 2ND UNLOCK OUTPUT
H2/7 GRAY/BLACK (-) DIESEL WAIT TO START INPUT
H2/8 BROWN / BLACK (-) 200Ma HORN HONK OUTPUT****(If not installing the siren)
Heavy gauge remote start, (H3) 10-pin connector
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT*******
H3/2 RED / WHITE (+) FUSED (30A) IGNITION 2 / FLEX RELAY INPUT 87*****
H3/3 ORANGE (+) ACCESSORY OUTPUT*****
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)******
H3/5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE)
H3/6 RED (+) FUSED (30A) IGNITION 1 INPUT******
H3/7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT
H3/8 PINK/BLACK (+) FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY
H3/9 RED / BLACK (+) FUSED (30A) ACCESSORY/STARTER INPUT******
H3/10 NC (no connection)NC
Remote start input, 5-pin connector
1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT******To ground
2 VIOLET/WHITE TACHOMETER INPUT WIRE
3 BROWN (+) BRAKE SHUTDOWN INPUT WIRE****** To DBALL if not D2D
4 GRAY N/O or N/C (-) HOOD PIN SWITCH INPUT**** To DBALL if not D2D
5 BLUE/WHITE (-) 200 mA 2ND STATUS/REAR DEFOGGER OUTPUT
Remote start auxiliary output, 5-pin
1 PINK/WHITE (-) 200mA FLEX RELAY CONTROL OUTPUT
2 ORANGE (-) 200mA ACCESSORY OUTPUT
3 VIOLET (-) 200mA STARTER OUTPUT
4 PINK (-) 200mA IGNITION 1 OUTPUT
5 BLUE (-) 200mA STATUS OUTPUT
Door lock harness, 3-pin connector
1 BLUE (+) LOCK (-) UNLOCK OUTPUT *****(N/C if using D2D)
2 EMPTY NOT USED
3 GREEN (-) LOCK (+) UNLOCK OUTPUT
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
jwrkailua
Member - Posts: 8
Posted: April 18, 2011 at 2:38 AM / IP Logged
I got all of the alarm functions to work, but the remote start does not work.  The error on the remote just says "remote start error".  There are no flashing parking lights, but the viper makes 8 clicking sounds.  There are no flashing lihts on the dball either.  The green light flashes shen I arm and disarm the alarm, but nothing when I try to remote start the car. Any ideas?  Thanks
jwrkailua
Member - Posts: 8
Posted: April 18, 2011 at 2:43 AM / IP Logged
I got the alarm to work, but the remote start does not.  There is an error on the remote that says"remote start error".  No flashing lights.  No green light flashing on the dball.  Any ideas?
syl20rochon
Copper - Posts: 298
Posted: April 18, 2011 at 5:26 AM / IP Logged
you're in manual transmission, change settings for automatic transmission. I think that it's in menu 4. It comes factory in manual.
Sylvain Rochon
I'm here to help.
