98 corolla with viper 5701
wojtek077
Member - Posts: 14
Posted: June 18, 2011 at 12:27 PM / IP Logged
i am getting confused about BLACK/ white wire(ignition 1 some say it is) and BLACK / YELLOW wire(Ignition 1 some say it is too) and my car BLACK/ white wire looks more like gray/white. Is their a way of testing them. I only know yellow/black powers dashboard like you would turn the key into on position.
Platinum - Posts: 7,828
Posted: June 18, 2011 at 5:08 PM / IP Logged
Test the vehicles ignition wires with a Digital Multi Meter.  Below is a guide for
wire identification.
Battery  +12V Constant:
Verification: This wire will register ( + ) voltage in all positions of the ignition
switch.
Ignition:
Verification: This wire registers voltage when the key is turned to the ON (or
RUN) position. The voltage does not drop out when the key is turned to the
START (or CRANK) position.
Starter:
Verification: This wire registers voltage only when the key is turned to the
START position.
Accessory Wire:
Verification: This wire registers voltage when the key is turned to ACC
(Accessory) and the ON (or RUN) position. The voltage drops out when the
key is turned to the START (or CRANK) position.
1998 Toyota   Corolla  ( Info from DEI.)
Signal                Color                       Location                                                           Viper H3
12volts              white (50A)  +       ignition switch, white 8 pin plug, pin 2            H3/2, H3/6, H3/9
Starter              red  +                     ignition switch, white 8 pin plug, pin 8 - cut    H3/4 Car Side, H3/5 Key Side
Ignition             BLACK/ white  +        ignition switch, white 8 pin plug, pin 6            H3/1
Ignition2           BLACK / YELLOW  +      ignition switch, white 8 pin plug, pin 4            H3/7
Accessory       blue/red  +             ignition switch, white 8 pin plug, pin 3            H3/3
This DEI info is only a guide and should be verified.  Wire colors can fade with age.
wojtek077
Member - Posts: 14
Posted: June 18, 2011 at 6:43 PM / IP Logged
Thank you for your reply it will save time
and also when i test wire ignition wires can voltage drop 10v in start position and increase to 13v or 14v or has to stay died on 12v
One more thing Remote start input, 5-pin connector and Remote start auxiliary output, 5-pin wire from does two connters are requered to just test if the remote will start the car. I just have Tach (VIOLET/WHITE) wire hacked up.
Posted: June 18, 2011 at 7:30 PM / IP Logged
A standard car battery will be about 12.3V.  While the starter is cranking it can drop to around 10V.  While the engine
is running and the alternator is supplying the vehicles needs, it will read around 14.3 V.
Remote start input, 5-pin connector                                                            Needed?              Use
1 BLACK/ WHITE (-)                NEUTRAL SAFETY SWITCH INPUT             Mandatory       If Auto Trans, connect to chassis ground.
2 VIOLET/WHITE                   TACHOMETER INPUT WIRE                        Optional           Most reliable remote start operation.
3 BROWN (+)                         BRAKE SHUTDOWN WIRE                           Mandatory       Connect to (+) Brake Pedal wire
4 GRAY N/O or N/C (-)           HOOD PIN SWITCH INPUT, ZONE 6             Mandatory       Connect to Hood Pin Switch
5 BLUE/WHITE (-) 200 mA     2ND STATUS/REAR DEFOGGER                Optional           Various uses
1 PINK/WHITE (-) 200mA     FLEX RELAY CONTROL OUTPUT                 Optional   Not needed on '98 Corolla
2 ORANGE (-)     200mA     ACCESSORY OUTPUT                                   Optional   Not needed on '98 Corolla
3 VIOLET (-)     200mA       STARTER OUTPUT                                         Optional   Not needed on '98 Corolla
4 PINK (-)       200mA          IGNITION 1 OUTPUT                                       Optional   Not needed on '98 Corolla
5 BLUE (-)       200mA         STATUS OUTPUT                                           Optional   Not needed on '98 Corolla
Posted: June 18, 2011 at 7:39 PM / IP Logged
Here is a link to the Viper 5701 Install guide :  https://www.the12volt.com/installbay/file.asp?ID=710
There are many things that need to be done for a successful install.  You will need it for setting the Program Options and the Tach Learn process, etc.
wojtek077
Member - Posts: 14
Posted: June 21, 2011 at 4:08 PM / IP Logged
thank you for the advice but remote start still does not work at list starts when i use the key. when i use the remote to start it takes long beep and show red by the function button.
t&t tech
Platinum - Posts: 2,622
Posted: June 21, 2011 at 6:00 PM / IP Logged
What error do you get from the parking lights?
wojtek077
Member - Posts: 14
Posted: June 21, 2011 at 11:00 PM / IP Logged
Hard count like 7,8 or 9 it blinked so fast
blanx218
Silver - Posts: 654
Posted: June 21, 2011 at 11:48 PM / IP Logged
The 5701 comes with the Manual Transmission mode as the default setting in menu 3. Follow the guide to change it to automatic and then program your tach, run time etc. and you'll be fine
t&t tech
Posted: June 22, 2011 at 8:10 PM / IP Logged
Tell me you're joking about the hard count.
Page of 3
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
