viper 5901 remote start 99 camry
brocknleslie
Member - Posts: 15
Posted: July 02, 2011 at 3:54 PM / IP Logged
Hi I have a viper 5901 and I can't get the remote start to work can someone tell me which wires I HAVE to use In order for the remote start to work and maybe the corresponding wires in my 99 camry ce.
deep bass
smokeman1
Platinum - Posts: 1,589
Posted: July 02, 2011 at 4:51 PM / IP Logged
What wires from the Remote Start, do you have connected to, what wires on the Camry?   Automatic or manual??
 What type/brand of bypass are you using?
Did you solder the connections?
Platinum - Posts: 7,828
Posted: July 02, 2011 at 4:55 PM / IP Logged
All wires should be located and verified using a Digital Multi Meter.  All connections should be
properly soldered and insulated.
You will also need a bypass module if you car is equipped with a transponder immobilizer system ( most are).
Here is a link to the DEI PKALL bypass module :  http://www.xpresskit.com/product.aspx?productid=196
    Viper 5901        '99 Camry @ Ignition Switch
H3/1 PINK (+) IGNITION 1                                                         BLACK / YELLOW
H3/2 RED / WHITE (+) FUSED (30A)                                        White
H3/3 ORANGE (+) ACCESSORY OUTPUT                           Blue/Red
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE)              Red - Cut
H3/5 GREEN (+) STARTER INPUT (KEY SIDE)                  Red - Cut
H3/6 RED (+) FUSED (30A)                                                     White
H3/7 PINK/WHITE (+) IGNITION 2                                          BLACK/ Red  *Viper factory default = Ign2
H3/8 PINK/BLACK (+) FLEX RELAY INPUT                          Not Used
H3/9 RED / BLACK (+) FUSED (30A)                                       WHITE/ Red
H3/10 NC (no connection)                                                       Not Used
Other Vipers wires necessary for remote start function
H1/2 +12v        WHITE/ Red or White @ ignition switch
H1/5 Chassis Ground
H1/8 Door Tridgger (-) necessary for programming                                  RED / White @ top of fuse box
H1/11 Parking Lights (+)   Set Viper Internal Fuse/Jumper to (+)           Green @ Bottom of fuse box
BLACK/ White   Neutral Safety Switch Input                                                     Read install guide
Violet/White  Tach Input for reliable remote start operation                      Black @ coil on 4 cyl
             ** Viper Programming Menu 3, Item 2, Option 4
Brown   (+) Brake Pedal Input        GREEN / WHITE @ bottom of fuse box
Gray      (-) Hood Pin Switch Input
Blue      (-) 200mA Status Output to bypass module G.W.R. Input
brocknleslie
Member - Posts: 15
Posted: July 02, 2011 at 5:02 PM / IP Logged
Right now it's all disconnected. I have a automatic and I don't have a by pass should I get one or can I do it without one? And I will solder when I'm done and know I have the right connections
deep bass
brocknleslie
Member - Posts: 15
Posted: July 02, 2011 at 5:13 PM / IP Logged
Where the black tach with located I can't find it, nor can I find the natural safety switch wire sorry for my inexperience
deep bass
brocknleslie
Member - Posts: 15
Posted: July 02, 2011 at 5:14 PM / IP Logged
Where's the black tach wire located*
deep bass
Posted: July 02, 2011 at 5:33 PM / IP Logged
Here is a link to an older Viper 5901 Install Guide :  https://www.the12volt.com/installbay/file.asp?ID=741
Your 5901 could have some differences with the H2 connector if it is of the newer style.
Wire color and name / description are still the same.
For an automatic vehicle, the Neutral Safety Switch wire connects to Chassis Ground.
DEI and Bulldog Security both have this info on the 4 Cyl Tach Wire :
On the 4 cylinder motor use the black wire in the gray plug at the coil on the drivers side of the motor.
NOTE #4; on the 4-Cylinder engine the BLACK wire is in a GRAY CONNECTOR located on
the COIL, drivers side of the engine.
AudioVox has this Tach wire info :
Tachometer     YELLOW/RED  (AC)       AT IGNITION COIL
It is possible that Pin 9 of the OBD2 connector, if Black, could be a Tach source.  Verify the Tach
signal with a DMM set to 20V AC, Red lead to the Tach wire and Black lead to chassis ground.  You
should get between 0.6 and 5V which will rise with RPMs.
Posted: July 02, 2011 at 5:37 PM / IP Logged
If your ignition key has a transponder chip, then you need a bypass.  A simple test is to get a plain metal key made at the hardware store for $1.99 and try it.  If the car starts and runs, you don't need a bypass.  ( if it doesn't start and run, you still have a safe, spare door key to hide under the bumper...)
brocknleslie
Member - Posts: 15
Posted: July 02, 2011 at 6:57 PM / IP Logged
I hooked up all the wire but the blue status wire, and should I hook the tach wire to the yellow/red or the black? I tryed black and it won't start it says" remote start error" and then the control module starts clicking.
deep bass
Posted: July 02, 2011 at 8:04 PM / IP Logged
Did you change the Vipers programming to Tach Mode?
Did you change the Vipers programming to Automatic Transmission?  Menu 3, Item 1, Option 2
Did you do the Tach Learn process?
Is the Neutral Safety Switch connected and in the ON position?
Are there any LED error blinks with shutdown diagnostics?
Try a remote start with a working ignition key in the the switch, but not turned.
Page of 3
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
