2001 Impala, Viper 5501 Remote Start
billy101
Member - Posts: 11
Posted: July 25, 2011 at 10:11 PM / IP Logged
Hi all, New to this forum but would like to get some help on installing a Viper 5501 Keyless Entry/Remote Start system. Here's where I'm running into a little trouble. My 2001 Chevy Impala LS has had a remote start system installed aftermarket for the last 6 years. The thing is, it uses the factory remote, which lacks the remote distance that is pretty much necessary for the remote start to be practical. To activate the remote start; on the keyless entry remote I press "Lock-Lock-Lock" within 7 seconds, and it will remote start the car, Press lock 3 times again, and the car will shut down. I plan on purchasing the 5501 pretty soon and will be installing it myself. The aftermarket alarm doesn't have a model or brand name, nothing on it, I also have no idea how it's wired in, but it's hooked up to another box that says Directed Electronics 457G on the box. When I googled, I found out that it's pretty much just the passlock bypass module? Does that sound right? Will I have to get the XpressKit from Viper as well? Or will the module I have now work with the new Remote Start / Keyless Entry? I can take pictures of what I have installed already if necessary.
Thanks for the help in advance!! Much appreciated!
Platinum - Posts: 7,827
Posted: July 25, 2011 at 10:35 PM / IP Logged
You can re-use the DEI 457G module.  Here is a link to the install guide  :  https://www.the12volt.com/installbay/file.asp?ID=609
It should be just a matter of switching the wires from the old R/S to the Viper, plus adding some additional
connections.  The connections to the car will not be changed, nor will it have to be re-programmed.
Here is a link to the DEI wire guides.  http://www.readyremote.com/main.asp  Look up your Impala for the wire locations
and colors.  The current R/S system should be connected to most of them.
Here is a link to the Viper 5501 Install guide.  https://www.the12volt.com/installbay/file.asp?ID=967  Read, review
& study.....  Practice soldering, too.  2001 Impala, Viper 5501 Remote Start -- posted image.
billy101
Member - Posts: 11
Posted: July 25, 2011 at 10:40 PM / IP Logged
Awesome man, just what I wanted to hear!! I'm SUPER talented with soldering. I'm only 16, but I have TONS of experience with soldering. I replaced all the halogen bulbs in my Instrument Cluster, HVAC Controls, along with the rest of the interior bulbs, and soldered LEDs and Resistors into the circuit boards of them all, without destroying them! I took an electronics class in my junior year where we practiced soldering wires and circuit boards as well.
I will read those articles over and over again. Thank you!!!!
billy101
Member - Posts: 11
Posted: July 25, 2011 at 11:37 PM / IP Logged
Quick question, Trying to pair the wires together before I even start it so I know what I'm doing before I go into it.
Do I connect the Viper Remote Start ONLY to the DEI 457G Module? I connect the wires to the 10pin connector coming from the module right? What wires do I connect to my car harness, if any at all?
Posted: July 26, 2011 at 6:26 AM / IP Logged
The DEI 457G will handle the Lock, Unlock, Trunk Release and Passlock2 immobilizer.  You will connect the Vipers
Lock, Unlock, Trunk Release and (-) Status Output to the 457G.  You can also connect the 457G's Door Status Output
to the Vipers (-) Door Status Input for alarm purposes.  If your Impala has the Factory Alarm system, notice that
the 457G will control that with the Lock and Unlock input signals.
Many Viper wires will still be connected directly to the vehicle.  Just like your current R/S system, all the main
ignition wires to the H3 connector.  All H3 wires except H3/7 will be connected.  Your car has two ignitions,
two accessory wires and one starter wire.  You might have one or two external relays used in the current system.
The Viper can directly handle IGN1, IGN2 ( flex relay ), ACC1, and Starter1.  You will need one extra relay for ACC2.
Other Viper wires to be connected are :  +12 Constant, Chassis Ground, Parking Lights, Horn Output ( optional ),
Neutral Safety, Tach, Brake and Hood Pin.
billy101
Member - Posts: 11
Posted: July 26, 2011 at 11:26 AM / IP Logged
This is really starting to get confusing haha.
What wires do the Door lock harness (3-pin connector) and the Remote start auxilary output (5-pin connector) go to? I can't seem to figure it out.
Here is how I have the connections to go as of right now.
From the 457G Module
Black - Already Grounded
Red - Already has +12V
Gray/Black - ?
RED / White - H1/1
BROWN / White - ?
Light Green - H2/2
Blue - H2/1
Violet - Remote Aux. Output (5-pin) Blue wire
Blue/white - ?
Green - H1/8
Are those correct? What other connections need to be made?
From Viper Module
H1 Connector
H1/3 - Black wire (Steering Column)
H1/8 - Blue wire (Gray 16-pin plug @ BCM)
H3 Connector
H3/1 - Ignition (Pink (+) @ ign. harness)
H3/2 - ?
H3/3 - Accessory (Orange (+) @ ign. harness)
H3/4 - Starter (Yellow (+) @ ign. harness)
H3/5 - ?
H3/6 - ?
H3/8 - ?
Remote Start Input (5-pin)
Pin #1 Neutral Safety Switch - ?
Pin #2 Tachometer - White (ac) Ignition Coil (how??? is this necessary?)
Pin #3 Brake Wire - White (+) @Brake Switch
Pin #4 Hood Pin - is this necessary?
Pin #5 2ND Status/Rear Defogger Output - where does this go?
I really need help....I appreciate your help thus far.
Posted: July 26, 2011 at 4:28 PM / IP Logged
Gray/Black -        Not Used
RED / White -        H1/1   Trunk Release
BROWN / White -     Not Used
Light Green -      Viper Door Lock Harness Green - Lock
Blue -                   Viper Door Lock Harness Blue - Unlock
Violet -                 Already connected to OBD2 Diagnostic connector Pin 2 Violet wire
Blue/white -        Viper Remote start auxiliary output, 5-pin,  Pin 5 BLUE (-) 200mA STATUS OUTPUT
Green -                H1/8 (-) DOOR TRIGGER INPUT
From Viper Module
H1 Connector
H1/2 -  +12V Constant
H1/3 -  Black wire (Steering Column) Horn
H1/5 -  Chassis Ground
H1/8 -  Green wire from 457G
H1/11 - Parking Lights  BROWN / white  (+)  passenger side junction block above kick panel
        ** Set Viper internal Parking Light Fuse/Jumper to +
H3 Connector
H3/2 - +12 constant Red @ ign. harness
H3/5 - +12 constant Red @ ign. harness
H3/6 - IGN2  Green @ ign. harness
H3/8 - +12 constant Red @ ign. harness
Pin #1 Neutral Safety Switch - Ground if auto transmission ( or Parking Brake )
Pin #2 Tachometer - White (ac) Ignition Coil - Most reliable method for R/S
Pin #3 Brake Wire - White (+) @ Brake Switch
Pin #4 Hood Pin - mandatory - install hood pin supplied with R/S kit ( or reuse current pin )
Pin #5 2ND Status/Rear Defogger Output - not used
Extra Relay for ACC2 :
Relay Pin 86 and 87 to +12V Constant thru 20A fuse
Relay Pin 85 to Viper Remote start auxiliary output, 5-pin, Pin 2 ORANGE (-) 200mA ACCESSORY OUTPUT
Relay Pin 30 to ACC2 Brown @ ign. harness
Relay Pin 87A not used - insulate
Things to watch for :
Is the cars' Yellow Starter wire cut?
Does the current R/S have a Hood Pin?  Can it be re-used?
Does the current R/S have any external relays?   Can the ACC2 relay/circuit be re-used?
Are the current wires well run and soldered?
As always, be sure to check and verify all wires with a Digital Multi Meter.  The vehicle wire guides are only guides...
billy101
Member - Posts: 11
Posted: July 26, 2011 at 9:17 PM / IP Logged
You are a life saver. Should the tach wire from the ignition coil already be at the remote start module?
It does not have a hood pin currently. I'm not sure if it has any external relays, as far as I can see there are none. I do not know how he hooked it up, but the a/c works when it's remote started, along with EVERYTHING else. It act's like the key is in and running, but it's not.
I'm not sure if the yellow starter wire is cut, I'll have to take a deeper look into it, but it's still connected at the ignition switch; and get's power when turned to CRANK, so is that a sign of something?
Posted: July 26, 2011 at 9:37 PM / IP Logged
It is possible the current R/S's Tach Input is already connected to the coil.
A hood pin is an important safety feature.  It prevents a remote start while the hood is open ( engine repair, etc ).  Try a remote start with the hood open.
Usually ACC1 runs the heat & A/C and ACC2 does the less essential things like radio, etc.
A cut Starter wire is for "Starter Kill" or "Anti-Grind".  It's something to be aware of when removing a R/S system.  Being that your current R/S system is an "add on" with no FOB's or security it might not be present.  Try a remote start and while the engine is running, without pressing the brake pedal, insert the key and rotate to "Start".  Does the starter engage and grind?
If you can get a Make / Model number from the current R/S unit, you could locate an install guide and know exactly what each wire is and where it should be connected.  That would make things easier during the change over.
billy101
Member - Posts: 11
Posted: July 26, 2011 at 10:12 PM / IP Logged
I know it does not have a hood pin for a fact, we have the hood off being repainted and I can still remote start the car.
Regarding the ACC1 & ACC2, they both must be hooked up somehow because everything works, radio, ac, the things that do not work are the blinkers, windshield wipers, basically anything on the multi-function switch.
I do not know if it has a cut starter wire because regardless if the car is remote started or not, if you start the car with the key, once the car is started if you turn the key it will NOT reengage the starter, I guess because everything is pretty much PCM Controlled.
When it's remote started and you get in the car, you can either turn it to "ON" and press the brake and be on your way, or turn it to "Start" and press brake and be on your way the same thing...the starter will not reengage once the motor is running - remote started or not.
I have the FCC ID and some other ID of the R/S Unit, I don't know if that will help at all if you want it, here it is.
FCCID: H50R39
IC: 1640B-R01
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
