Posted: September 23, 2011 at 8:48 PM / IP Logged
Posted: September 23, 2011 at 9:15 PM / IP Logged
Posted: September 23, 2011 at 9:23 PM / IP Logged
Posted: September 23, 2011 at 10:24 PM / IP Logged
Posted: September 23, 2011 at 10:35 PM / IP Logged
Posted: September 24, 2011 at 9:12 AM / IP Logged
Posted: September 24, 2011 at 10:31 AM / IP Logged
Posted: September 24, 2011 at 9:01 PM / IP Logged
Posted: September 24, 2011 at 9:12 PM / IP Logged
Posted: September 24, 2011 at 9:20 PM / IP Logged
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I do remember seeing the picture of a 7 pin plug on the idatalink information sheet, but I could not locate a similar 7 pin plug anywhere, so I assumed it was 4 and 5 pin plugs. It is already 2230 here, so I've already wrapped everything up. I will double check to see if it is equipped with an immobilizer and also try to remote start without the by pass module once I have some time to work on it again. I will keep you guys posted on the status. Once again, thank you.
