vehicle injection computer
naldo
Member - Posts: 20
Posted: October 25, 2011 at 11:14 PM / IP Logged
Please i need a vehicle injection computer diagram for 06 toyota sienna LE, i am looking for a speed detection circuit lead to connect the after market navigation..thank you
Platinum - Posts: 13,725
Posted: October 25, 2011 at 11:34 PM / IP Logged
You need to find a speed sense wire.  Fuel injector / Tachometer wiring have nothing to do with speed of the vehicle.
naldo
Member - Posts: 20
Posted: October 26, 2011 at 6:50 AM / IP Logged
Where/how can i find it? Any idea what colour is the wire? Coz i have no idea..thanks
flobee4
Silver - Posts: 585
Posted: October 26, 2011 at 9:22 AM / IP Logged
The color is PURPLE / white
Its found in a few locations. First it should be in one of the plugs at the back of the factory radio. That would make it really easy. It also can be found at the ECM located behind the glovebox, in the second plug down from the top. Its also found behind the instrument panel, pin 36 of the 40 pin plug that is plugged into the cluster.
naldo
Member - Posts: 20
Posted: October 26, 2011 at 10:18 AM / IP Logged
Is this the speed detection circuit lead? Thanks
naldo
Member - Posts: 20
Posted: October 26, 2011 at 2:23 PM / IP Logged
Anyone know if i need a module for 06 sienna LE? I want to put a pioneer avic-n1 with navigation, please let me know!! Thanks
flobee4
Silver - Posts: 585
Posted: October 26, 2011 at 4:07 PM / IP Logged
yes this is where you would connect your Pink "speed sense" wire coming off the Pioneer unit. The speed sense wire is a direct connection, no module needed.
As far as the rest of the basic wiring, I would only recommend you using a wiring harness. Check your vehicle at Metra Web site for which wiring harness and which dash kit you might need to make your install go smoothly.
naldo
Member - Posts: 20
Posted: October 27, 2011 at 7:15 AM / IP Logged
Is it purple with white or purple & white? Just want to make sure!! Thanks
naldo
Member - Posts: 20
Posted: October 27, 2011 at 9:43 AM / IP Logged
I found the wire but the unit does'nt came on,,do u know why? I check all the connection everything was ok, maybe there is something with unit? How to check the unit if its working?thanks a lot..
flobee4
Silver - Posts: 585
Posted: October 27, 2011 at 12:12 PM / IP Logged
Check for 12volt at your red wire, yellow wire, and make sure you have ground at your black wire. For checking you will need a Voltmeter or a Test light. If you have 12volts and ground, the radio should at least turn on. Also, make sure the N1's brain is plugged in securely at both the head unit and brain box.
