python 991 in rsx remote start
keanevann
Posted: December 31, 2011 at 9:52 PM / IP Logged
Hi everyone. I have a 2004 Acura RSX and i have installed a Python 991. Everything works except the remote start. I have the transponder bypass installed. This is what I have for wiring up the remote start wiring harness.
Python 991 RSX
Pink    (Ign 1)           BLACK / YELLOW
RED / Wht (Ign 2)           Not Connected
Orange (ACC)             WHITE/ Red
Violet (Starter Car Side)BLACK/ White (Car Side)
Green   (Starter Key Side)BLACK/ White (Key SIde)
Red     (Ign 1 Input)     Not Connected
Pink/Wht(Ign 2)           Not Connected
Pink/Bla(Flex Relay Input)Not Connected
RED / Bla (Acc/Starter Input)              Not Connected
As I said before I know this is wrong because it doesn't start.Can someone help me out and please provide the correct connections. Thank you in advance.
keanevann
Posted: December 31, 2011 at 9:53 PM / IP Logged
All RSX's are the same wiring but if needed its a 2003 Acura RSX Auto Trans. Thanks.
tedmond
Gold - Posts: 4,610
Posted: January 01, 2012 at 9:31 AM / IP Logged
you have no power for RED, RED / BLACK,RED / WHITE
connect those 3 to a constant 12v source.
Ted
Compustar Expert
Posted: January 01, 2012 at 9:54 AM / IP Logged
Apart from that obvious blooper was there an ACC II back then Ted?
keanevann
Posted: January 01, 2012 at 12:24 PM / IP Logged
Thanks Ted..... I guess it helps to read the instructions right..... for some reason my brain saw input and thought that it needed to go to an input not that it was an input...blooper indeed
shortcircuit161
Silver - Posts: 556
Posted: January 01, 2012 at 1:06 PM / IP Logged
I agree with both Ted and Howie.
Directwire shows 2 Accessory wires for this year.
12volts      white (40A or 50A)
Starter      BLACK/ white
Ignition BLACK / YELLOW
Accessory BLACK/ red
2nd Accessory WHITE/ red
Also make sure you program the pink/white wire for 2nd Accessory in the Remote Starter features menu.
Good luck and please let us know how it worked out.
tedmond
Gold - Posts: 4,610
Posted: January 01, 2012 at 6:00 PM / IP Logged
when i installed a compustar into this car, i know i uesd the additional ignition wire but left it for acc 2.
the second acc is for Radio and Defrost. since you have a 5th relay output (ign2 pink/white) just use it anyways.
Ted
Compustar Expert
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
