2001 gmc yukon xl and clifford 50.7x
marshallstone
Posted: January 05, 2012 at 11:47 AM / IP Logged
Hello all,
I have a remote start from clifford 50.7x, a 2001 gmc yukon xl, and a pljx bypass that I want to install. Now, my issues: I have the remote start, but there was no install guide in the box, and I am having trouble finding one online. Also, I want to make sure that the guides posted here for a 2000-2002 suburban will also work for me. I know they are the same vehicle but I want to make sure that all the wiring is the same. Anyhow so I guess I'm requesting for a diagram of the alarm and a diagram of the truck. If anyone could let me know any issues I might run into, that would be great. Also how to wire the pljx... I got the diagram from xpresskit.com and its pretty vague. Any help would be great!!! Thanks,
Marshall
shortcircuit161
Silver - Posts: 556
Posted: January 06, 2012 at 9:06 AM / IP Logged
I just uploaded the file to the Downloads/Manuals section. Enjoy!!
shortcircuit161
Silver - Posts: 556
Posted: January 06, 2012 at 9:15 AM / IP Logged
Hope this helps.
2001 gmc yukon xl and clifford 50.7x -- posted image.
shortcircuit161
Silver - Posts: 556
Posted: January 06, 2012 at 9:18 AM / IP Logged
I didn't realize how small the diagram would look. I will post a better copy.
shortcircuit161
Silver - Posts: 556
Posted: January 06, 2012 at 9:25 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - GMC / YUKON / 2001 / Remote Start
12volts
red (40A)      +      ignition harness
Starter
yellow      +      ignition harness
Second Starter
N/A
Ignition
pink      +      ignition harness
Second Ignition
white      +      ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
N/A
Accessory
orange      +      ignition harness
Second Accessory
brown      +      ignition harness
Keysense      lt. green      -      ignition key switch
Power Lock
lt. blue      +      BCM, brown plug, pin A4
Notes: The BCM (Body Control Module) is under the driver dash.
Power Unlock
white      +      BCM, brown plug, pin A3
Notes: The BCM (Body Control Module) is under the driver dash. On some models, to unlock the driver door only, use lt. green (-) at the BCM, lt. blue plug, pin A4.
Lock Motor
gray      5 wire      driver kick, door harness
Unlock Motor
tan      5 wire      driver kick, door harness
Parking Lights+
brown      +      BCM, lt. blue plug, pin B6
Parking Lights-
white      -      BCM, lt. blue plug, pin A5
Hazards      same as turn signals
Turn Signal(L)      lt. blue      +      turn signal switch
Turn Signal(R)      dk. blue      +      turn signal switch
Reverse Light      lt. green      +      inside rear view mirror
Door Trigger
tan      -      BCM, purple plug, pin B4
Dome Supervision
gray/black (dome lamp), dk. green (puddle lamp)      -      BCM, lt. blue plug, pins A3 and A8
Trunk/Hatch Pin
pink/black      -      BCM, lt. blue plug, pin B10
Hood Pin
N/A
Trunk/Hatch Release
locks/unlocks along with doors
Power Sliding Door      N/A
Factory Alarm Arm
arms on lock with door open
Factory Alarm Disarm
lt. green (driver door key cylinder)      -
BCM, purple plug, pin B3
Disarm No Unlock see factory alarm disarm
Tachometer white ac ECM, plug labeled red, pin 10
Notes: The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover.
Wait to start      N/A
Brake Wire white + brake switch or steering column
Parking Brake      lt. blue      -      parking brake switch
Horn Trigger
black      -      BCM, brown plug, pin A9
Memory Seat 1      white      +      memory module under driver seat
Memory Seat 2      purple      +      memory module under driver seat
Memory Seat 3      N/A      +
Interface Module:     Category:
Immobilizer Bypass      Required:
Yes
Type:
Passlock II
Part #: GMBP
Alternate Part1 #: PLJX
Alternate Part2 #: 556LW
Alternate Part3 #: 555LW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes:
Combo Interface      Required: No
Type: Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year. Key sense input of the 1700G is not needed when using it on GM Trucks
marshallstone
Posted: January 08, 2012 at 11:19 AM / IP Logged
Thanks for the diagram for the truck. I really appreciate it. What I really needed though was the diagram for the alarm itself. It did not come with one at all.
marshallstone
Posted: January 08, 2012 at 12:30 PM / IP Logged
Never mind I'm an idiot, I found it in the downloads section... Thanks guys let you know if I have any issues!
marshallstone
Posted: January 08, 2012 at 4:08 PM / IP Logged
So, I am having difficulties installing this... I'm not sure what the labels on DEI's stuff means, can you or someone else possibly tell me what I need to connect where??? I found all the wires that were on the direct wire diagram inside of the truck. What I don't understand is what wires from the alarm harness I hook where... I'm assuming I have to make the door locks a positive output???
shortcircuit161
Silver - Posts: 556
Posted: January 13, 2012 at 6:27 PM / IP Logged
I'm sorry about the late reply. My next post will go into a little more detail about where to connect most of the wires.
shortcircuit161
Silver - Posts: 556
Posted: January 13, 2012 at 7:02 PM / IP Logged
On the thick gauge harness (10 pin harness)
Pin H3/1 - Pink - connects to the Pink ignition wire
Pin H3/2 - RED / White - connects to the Red 12v constant wire
Pin H3/3 - Orange - connects to the orange accessory wire
Pin H3/4 - Violet - connects to the yellow starter wire
Pin H3/5 - Green - not used unless you want the starter anti-grind function (optional)
Pin H3/6 - Red - also connects to the Red 12v constant wire
Pin H3/7 - Pink/White - connects to the white 2nd ignition wire (must connect this wire to prevent possible transmission damage or check engine light from coming on)
Pin H3/8 - Pink/Black - (optional) no connection (just cut and tape it)
Pin H3/9 - RED / Black - also connects to the Red 12v constant wire
Pin H3/10 - No Connection
There is also a 2nd Accessory wire (Brown) that will require a relay to power up.
- Connect Pins 30 and 85 to the Red 12v constant wire of the car
- Connect Pin 87 to the Brown 2nd Accessory wire of the car
- Connect Pin 86 to the orange wire (H2/12) of the 18 pin Viper harness
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
