stellar rs1050 wire info on 03 silverado
jen1110bill
Member - Posts: 41
Posted: February 22, 2012 at 3:36 PM / IP Logged
this isnt my first rs install but it is with this brand, the guy wants to keep his factory key fob so he already got me this unit, there are 2 wires 1) activation input 2) bypass output, now where in the vehicle would these be wired to? its a 2003 chevy silverado 1500 4.8l auto, also i cant see where any of the wiring from unit hooks to factory disarm, is one of those two wire go to that?
thanks bill
metz35
Copper - Posts: 458
Posted: February 22, 2012 at 4:22 PM / IP Logged
Activation input goes to lock or unlock motor. However he wants it to start by hitting lock x amount of time or hitting unlock x amount of times.
The bypass wire is for the bypass.which ever bypass you choose to use to circumvent the passlock 2 system.
jen1110bill
Member - Posts: 41
Posted: February 22, 2012 at 4:54 PM / IP Logged
Ok thanks, i should also diode isolate that acktivation wire too correct?
bill
metz35
Copper - Posts: 458
Posted: February 23, 2012 at 5:09 AM / IP Logged
You can if you want the worst thing that will happen if you don't is he will be able to start it with the switch on the door panel
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
