2012 infiniti g37x, viper 5501
cpuguy06
Copper - Posts: 94
Posted: October 29, 2012 at 4:37 PM / IP Logged
I did try cutting off the toggle switch and hooking up a different toggle switch. That didn't do it and then I remembered that when I had it hooked up in my car, the ignition was pulsed whenever I locked the car. After looking at the wire diagram the correct way it made sense...I had a wire in what I thought was the Ignition 1 (-) spot on the harness and it turned out to be in the OEM Alarm Arm position. The wire was hooked up to the Ignition 1 (-) on the car. Oops, at least the polarities were the same. Thanks again everyone!
cpuguy06
Copper - Posts: 94
Posted: November 23, 2012 at 7:11 PM / IP Logged
Everything is in (finally) and working...except for one minor annoyance. When I remote start and get in to take the vehicle over, as soon as I press the brake the car dies and I have to start it again. In my last car (2011 Altima with push to start), I was able to remote start, get in and put my foot on the brake and the car would light up "ACC", then "ON" and I could drive away. Am I missing something in the configuration or what here? Thanks all!
Platinum - Posts: 7,787
Posted: November 23, 2012 at 7:35 PM / IP Logged
Maybe, you should enter the vehicle ( with the KeyFOB ), the START button should start blinking, then press the START button twice and then depress the brake pedal.
cpuguy06
Copper - Posts: 94
Posted: November 23, 2012 at 9:25 PM / IP Logged
Tried that, start button doesn't blink, the take over works, but leaves the red security light on even after driving off.
Posted: November 23, 2012 at 9:39 PM / IP Logged
Not a big DEI bypass user ( mainly iDatalink ) but..
Did you use the DB-ALL Type 1 install diagram and cut the Security Light wire and connect the DB-ALL
wires from Pin 10 & 11 of the 14 Pin Plug?
cpuguy06
Copper - Posts: 94
Posted: November 24, 2012 at 11:52 PM / IP Logged
I did use the DB-ALL type 1 diagram. I'll check the connections for the security light and see what I did. Thanks!
Page of 3
